Message 1 of 10
05:44 AM
I've been trying to cut an M12 thread but is't as if it's the wrong pitch?
The O/D is good, the thread depth is good, but it looks/feels like the pitch is slightly off.
It's feeding at 1.75 in the G code but a nut won't go on.
I've tried CSS and fixed, same problem. Canned cycle (G92) and without (G32). (without is a better thread* but still not correct)
When I use the machines G76, it's good.
Could it be related to the way the tool geo is set-up? It's set at 1.75, would the Tip compensation have an effect?
* With the canned cycle, it tends to damage the last-but-one thread slightly, it doesn't happen without it.
