O/D Threading help on HAAS ST-30
Message 1 of 10
I've been trying to cut an M12 thread but is't as if it's the wrong pitch?
The O/D is good, the thread depth is good, but it looks/feels like the pitch is slightly off.
It's feeding at 1.75 in the G code but a nut won't go on.
I've tried CSS and fixed, same problem. Canned cycle (G92) and without (G32). (without is a better thread* but still not correct)
When I use the machines G76, it's good.
Could it be related to the way the tool geo is set-up? It's set at 1.75, would the Tip compensation have an effect?
* With the canned cycle, it tends to damage the last-but-one thread slightly, it doesn't happen without it.
Replies (9)
Message 2 of 10
Laurens-3DTechDraw
Do you have an infeed angle set?
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
Found out the hard way is the best way to win.
Message 3 of 10
Only thing I can suggest is lay a bolt up next to your threads, and see whats different.
Message 4 of 10
It's feeding in from 1mm off the job, the angle's set at 0 at the moment.
Message 5 of 10
The threads look very close but don't quite mesh. A nut will go on about 1 turn before locking.
Message 6 of 10
Rob_Lockwood
then perhaps the fix is to have your post processor altered to output threading cycles using g76.
Rob Lockwood
Maker of all the things.
| Oculus | | Locked Tool | | Instagram |
Message 7 of 10
I could do that, yes, but I'm just trying to understand why it's doing what it is.
Does the In-feed angle have to be half the insert angle? eg, 30° for a 60° 1.75mm ISO insert?
Message 8 of 10
Laurens-3DTechDraw
We run the infeed angle usually anywhere between 26 and 30.
Laurens Wijnschenk
3DTechDraw
Message 9 of 10
jeff.walters
I have seen this before where a machine works (reacts) differently when doing synchronized turning (G92, G32, G33) and running a canned cycle (G76, G78). Sometimes it’s a matter of slowing down the spindle to give the machine time to sync the feed better, the other thing is the decimal for the feed may need to be carried out a bit farther to be more “exact”. In a canned cycle (G76) you are giving the control the pitch and then it is doing all the synchronized turning calculations and will adjust the actual feed to what it needs.
Jeff Walters
Senior Support Engineer, CAM
Message 10 of 10
Just a follow-up on this.
The thread was off due to my error. ::)
I wasn't giving it enough of a lead to get in sync before cutting. Since increasing that, it's cutting great.  🙂
Thanks all for the help/suggestions.
