2d Pocket BUG??
2d Pocket BUG??
karolis.s
2d Pocket BUG??
karolis.s
Hello, I couldn't find answer in forum or in HELP of Inventor CAM..
Is this some kind of bug or I just need to input correct parameters somewhere? Or maybe there is another macro in CAM which avoids milling unwanted parts?
Marco.Takx
Hi @karolis.s,
This is no bug.
2D operations don’t look at your model.
Because you have created a open loop it things it has enough room to go outside the selected geometry.
Try a 3D pocket and select only the area that you like to Mill.
You will see that a 3D opeeation is looking at your model.
Hope this
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
