- Mute
- Permalink
- Report
When I attempt to run a lighting analysis in the cloud I get the following error:
I am only able to get the plug-in to run by detaching and discarding worksets. If I detach and preserve worksets the lighting analysis plug-in will not function. Ideally I would be able to use the plug-in on a workshared model.
I'm using the latest version of the plug-in for Revit 2015. A co-worker is using a previously downloaded version of the plug-in and she seems to be able to run the lighting analysis plug-in on a workshared model.
Are other users getting the above message when running the plug-in on a workshared model or am I alone in this? If this message were so common I would think I would have seen other members commenting on it, but I don't find any other threads/posts mentioning this.
