I'm trying to use the Lighting analysis plugin in Revit 2018.
Sometimes it works well but often I get the error "Unable to charge account. Please try again".
I'm logged in with my Autodesk account. I tried several times. I also closed Revit and restarted it. I've also tried to logout and login again.
It sounds like you may be having some internet connections issues. Are you able to navigate to other websites when this happens?
Dear,
Thanks for your feedback. It is not an internet issue because when I have this error internet is up and running (I can browse other sites).
Within Revit I can also run new analysis during which data is uploaded without any problems. I can also access older results.
But new ones not. It's quite strange because when I try the day after: most of the times I don't get any error (result is downloaded).
Do you have the Revit 2018 Insight plug-in installed? https://insight360.autodesk.com/oneenergy/Landing/Download
Let us know if you have more questions on this topic, otherwise please accept as a solution so that others can benefit from this information.
Yes. I had to do it because in 2018 by default the tools were not yet available, so I downloaded them.
Sorry, but I'm going to have to refer you to the Autodesk Support center for help on the Cloud Credits. Looks like it might be beyond the Lighting Analysis tool.
Also, FYI, here is some more information about Cloud Credits: https://knowledge.autodesk.com/customer-service/account-management/subscription-management/subscript...
