I have the same question. I need to teach this in my class for Fall 2023. The Lighting Analysis button under Energy Analysis is missing in Revit 2023. Thanks to anyone who has the answer.
Okay, I've found out how to install Revit 2023 Lighting Analysis and Solar Analysis. You need to go to your account and under "All Products and Services" select "Revit." Then go to "Updates & Add-ons" then scroll down until you find "Lighting Analysis for Revit 2023" and "Solar Analysis for Revit 2023." See screen capture below.
Hi!
I can not see these two plugins in my list! It is the same problem I had before and I got the plugins via mail.
Shall I create an issue to get those to Revit 2023?
best regards
I could not find it as described, though I found it here and listed under "extensions" list.
https://manage.autodesk.com/products/RVT?version=2024&platform=WIN64&language=EINT
Thank u..You are amazing and provided the information smoothly
Thank u..You are amazing and provided the information smoothly.
H. I. M. K.
