revit 2024 "Failed to Generate Results. Please see Log File" when running an Insight Daylight Analysis
tdallamora
tdallamora
after the analysis, the import phase doesn't run and the view _insightlighting plan disappears with the message "Failed to Generate Results. Please see Log File".
I've tried the proposed solution for previously version, but without solving the issue,
thanks for your collaboration
fsg123
Hey there. I was experiencing the exact same issue and couldn't get my head around it for a while. I finally realised it was down to some incompatibility with the language package I was using (Spanish).
I switched Revit back to English and the problem was gone. Even results for previous analysis that I'd run while using Revit in Spanish could be loaded into views.
Hope this helps.
Cheers.
