- Mute
- Permalink
- Report
I am trying to run a lighting analysis for my project. I get results saying that the Attic Floor is outside of the threshold, which shouldnt matter because there are no regularly occupied spaces in the Attic. I have unchecked "include in daylighting analysis" for all the rooms in the attic using the Lighting Analysis Room Schedule. Then reloaded the analysis. However, now when i go to the Floor Schedule, it says there is still 2,000sf of 6,000sf being included in the analysis. Some of the rooms are still displaying with colors on the floor plans but the rooms are unchecked. Why is this happening? It also seems like the total floor areas of all my levels are higher than they actually are. Any ideas?
UPDATE: When i sort and group the rooms in the "Lighting Analysis Room Schedule" and calculate totals, the Attic has 4,000 square feet. But the "Lighting Analysis Floor Schedule still lists 6,000sf. Where is this extra 2,000sf coming from? Thickness of walls? Is there a way to turn that off? Its hard to tell if this is skewing my results or not. Thanks!
