Insight Plug-in for Revit 2021
samuelsanf
Mentor Mentor
Message 1 of 30
samuelsanf
When would be available the Insight plugin for Revit 2021?
J. Samuel Santana F.
¿Te resultó útil esta publicación? Dale a Me gusta.
¿Tú pregunta fue respondida correctamente? Haz click en el botón ACEPTAR SOLUCIÓN.
Replies (29)
Message 2 of 30
samuelsanf
Just installed the solar and light analysis plugins from Autodesk Desktop App
Message 3 of 30
Can you please provide me with a setup of these plugins since I am unable to find them in my Autodesk download manager
Message 4 of 30
m.sakikhales
Community Visitor
Community Visitor
Hi, I couldn't find any of these files on Autodesk App. Could you please post the links of these files. Thanks.
Message 5 of 30
Message 6 of 30
Thanks for your support.
Message 7 of 30
hi Sir,
Thanks for your help already. Can you also post the solar analysis plugin? The link you shared is the plugin for the lighting analysis right?
Kind regards,
Naut Loots
Message 8 of 30
Message 9 of 30
Hamad.gmc
The ones you posted are solar and lighting analysis. Do they cover all the aspects withing Insight energy analysis?
Message 10 of 30
im sorry, but it some how did not work for me..
Message 11 of 30
Hey after many updates, it did work for me... thank you so much 👍
Message 12 of 30
brj
So where is the plugin for 2021?
"Since Revit 2021, Solar Analysis and Lighting Analysis are available to download from accounts.autodesk.com"
When I follow the link I end up the same place where I get the above message?
Message 13 of 30
tony.saracino
Hello All-
If you go to  https://accounts.autodesk.com  and search 'Analysis for Revit' you will see the two plugins for download. See attached screenshot.
These plugins are no longer available at  https://insight.autodesk.com/oneenergy/Landing/Download  but instead are accessed through your Autodesk Account login.
This is where new plugins and updates should be downloaded and installed from.
Best,
Tony
Message 14 of 30
ckstaton1
Observer
Observer
Hi Tony,
I am still struggling to find the version of the Solar Analysis Insight that's compatible with Revit 2021... I followed the link you suggested but it comes up with way more options that just two, and non of them are the Insight add-in. I've attached a screengrab of what I see.
Each time I think I might have found it it takes me back to the list of downloads which only has up until 2020!
Any suggestions would be appreciated.
Message 15 of 30
ckstaton1
Observer
Observer
Thankyou for sending this. How should this be installed into Revit 2021 once its downloaded? When have double clicked on it after downloading, a load bar appears for a second but quickly disappears- something seems to be going wrong.. Am I missing something ?
Message 16 of 30
tony.saracino
If you open Revit 2021 there should be new icons near the Energy Analysis icons.
Message 17 of 30
va346
Observer
Observer
To access from the Autodesk homepage, I found it on the Product Updates section. My account > Product Updates, scroll and the two plug-ins are listed for Revit 2021. I've attached a screenshot.
Message 18 of 30
0355431
Observer
Observer
I downloaded the Solar Analysis and lighting analysis from the autodesk user account to my 2021 revit student trial. After the download a "already installed" message prompts up. I still don't have plug in installed..
Message 19 of 30
tashmargetic
Community Visitor
Community Visitor
Thank you for this!
Message 20 of 30
Olá, a versão do pluguin 2021 não está aparecendo.
Alguém sabe onde consigo baixar?
