Inventor Publisher
Welcome to Autodesk’s Inventor Publisher Forums. Share your knowledge, ask questions, and explore popular Inventor Publisher topics.
Part list preview
5 REPLIES 5
680 Views, 5 Replies
Part list preview
Hello All,
I have a problem while working with Inventor Publisher 2013.
After creating a part list in Publisher, the previews are not displayed in the part list.
Even if I double click in the table in the preview column, I zoom and drag until the part is inside the box, but still with no result when I press the return button.
Tiziano
Tags (3)
5 REPLIES 5
TimeraAutodesk
Hi Tiziano,
It sounds like you don't have the Preview specified to be shown in the parts list. If you select the Customized Fields button from the top left corner of the Parts List Dialog, you can move over all the items you want shown in your list. Ensure that "Preview" is moved to the right hand column so that it shows up when you generate your list. See below:
Happy Publishing,
Timera
in reply to: TimeraAutodesk
Hello Timera,
I have the Preview specified in the part list.
Tiziano
TimeraAutodesk
Thanks Tiziano,
If you wouldn't mind sharing the file you're having this issue with, we could take a closer look to see if we can pinpoint the problem.
Please email me directly at timera.hart@autodesk.com if you'd like to send the IPB file.
Timera
hello all,
I found the cause of the problem.
When I click in the partlist on the preview, I get the view diplayed on the attached "screenhot 1"
The screenshot must make everything clear.
Tiziano
hello all,
Tiziano
