I just upgraded a mobile workstation with Inventor Publisher 2013 and we are having major performance issues. I reinstalled Inventor Publisher 2012 and we have no performance issues. I'm getting ready to upgrade my entire industrial engineering department and I do not want to have performance issues.
Does anyone else notice a performance change between Publisher 2012 and 2013
Here is the users mobile workstation specs
Dell Precision M4500
Core i7 1.73 Ghz processor
8 GB RAM
Nvidia Quadro FX 1800M
Graphics driver 9.18.13.593
Windows 7 x64
Solved by jweiss1313. Go to Solution.
Hi John,
Thanks for your feedback and I am sorry you meet the performance issues in Publisher 2013, could you please provide us more detail information about the performance issues you met?
Irene Chen (irene.chen@autodesk.com)
Inventor Publisher
Hello Irene,
Once the Inventor assembly was inserted, moving parts were painfully slow. It took time for the 3D triad to appear and movement was slow and choppy to the point it was unmanageable. Button in the interface took time to iluminate so they could be selected and playing the animation was slow, choppy and robotic like instead of smooth. Saving the file even took a very long time. It took a very long time just swithing between different snap shots as well. Once we reinstalled Pub 2012, we saw a drastic difference in overall performance and the the user was able to get his work done.
I'm going to try to install it on another laptop and see if it has the same issue. I will let you know what I find out.
If you check your records, we were one of the first companies to purchase Inventor Publisher. We love the product when it works. We have had major problems with every new release and I dread rolling this new releae out after seeing the poor performance compared to Pub 2012. I need to know honestly whether or not there is an issue and whether or not Autodesk is aware of it and is working to fix the issue. I don't want to roll this new release and have my users unable to do their work.
Best regards,
Hi John,
I am glad to hear that you love publisher and thanks for your feedback, but I can't reproduce it at my side, Does this happen to the special files or all files? could you provide us more detail information listed below?
Inventor Publisher QA
Here are the system specs you requested
8 GB RAM
Windows 7 x64
Autodesk Inventor Publisher 2013 (SP3)
I can share the file is you like. Me email address is johnweiss@follettice.com
Thanks!
HI:
Please post a resolution to this issue when you find one. I am very interested to know the results, as we have a similar performance issue, although ours may be due to a slow graphics card.
Hello Irene,
Looks like it was isolated to one laptop where I had other issue related to the graphics card/driver. I installed Publisher 2013 on other laptops and workstations and I don't see performance difference between 2012 and 2013. Thanks for your help!
I have the same issue with my machine to the extent where I've had to uninstall Publisher 2013 and revert back to Publisher 2012 because it simply un-usable. The graphics are just sooooo sloooooowwwwww.
Workstation spec:
HP XW6400 Workstation
Intel Xeon 2.33 Ghz processor
4 GB RAM
Nvidia GeForce GTS450
Graphics driver 9.18.13.697
Windows 7 x64
SpacePilot Pro (Driver 6.14.0)
Does anyone have any suggestions? Other than get a new machine of course....
Regards
Ben
hello,
I have excat the same issue very poor performance on graphics. I have tried it on 3 different computers:
1:
Win xp 32 bit Proffesional
HP xw 4600
Fx 1800
4 Gb mem
2:
Win 7 64 bit Enterprice
HP Z 420
Fx 4000
24 Gb mem
3:
Dell M6700
Quadro K4000M
16 Gb mem.
all installed from same media all with SP 1,2 & 3. I have update everything, windows, spacepilot, directx, graphics I even have tried with several certified drivers - no luck.
data amount for the model around 1Gb.
performance on 3D rotae is very poor, and if a section cut view is active it´s imposible to rotate.
please provide a solution asap.
Thanks for the feedback, do you mind sharing the files which you used for reproduce this issue to me?
Irene Chen(Irene.chen@autodesk.com)
