WorkPoint_SetByCurveAndEntity (3D Sketch and plane)
8 REPLIES 8
Message 1 of 9
942 Views, 8 Replies
I would like to create a workpoint in each line in the 3d skecth that intersect to the plane.
The code below doesnt work even with the 3d sketch that has only one line.
 Please see the attached part file.
Thank you in advance.
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oDef As ComponentDefinition = oDoc.ComponentDefinition
Dim oWP As WorkPlane = oDef.WorkPlanes.Item("WorkPlane_Mid")
MsgBox(oWP.Name)
Dim oSketch As Sketch3D = oDef.Sketches3D.Item("3D Sketch1")
MsgBox(oSketch.Name)
Dim oWPt As WorkPoint
oWPt.SetByCurveAndEntity(oCurve, oWP)
MsgBox(oWP.Name)
Tags (2)
Labels (2)
8 REPLIES 8
Message 2 of 9
nmunro
nmunro
A couple of things:
  • Your code makes reference to 3D Sketch1 whereas in your file, the sketch is named 3D Sketch2
  • You must create the Workpoint since it does not exist in the model. Instead of declaring a workpoint variable and then calling SetByCurveAndEntity, you must add the work point to the model with the corresponding AddByCurveAndEntity method. I used VBA below to accomplish this, you should be able to translate it back to your iLogic code quite easily.
  • Note that the error handling is required (Try-Catch in iLogic) as an exception is raised if their is no intersection.
  • If you have other types of entities (i.e. arcs) in your 3D sketch, you will need to check those as well for the intersection.
Public Sub CreateWP()
    Set oDoc = ThisApplication.ActiveDocument
    Dim oDef As PartComponentDefinition
    Set oDef = oDoc.ComponentDefinition
    Set oWP = oDef.WorkPlanes.Item("WorkPlane_Mid")
    Set oSketch = oDef.Sketches3D.Item("3D Sketch2")
    Dim i As Integer
    Dim line As SketchLine3D
    On Error Resume Next
    For i = 1 To oSketch.SketchLines3D.Count
        Set line = oSketch.SketchLines3D.Item(i)
        Set oWPt = oDef.WorkPoints.AddByCurveAndEntity(line, oWP)
        If Not oWPt Is Nothing Then
             Exit For
         End If
    Next i
End Sub
https://c3mcad.com
A couple of things:
    Dim i As Integer
             Exit For
         End If
    Next i
End Sub
https://c3mcad.com
Message 3 of 9
in reply to: nmunro
Thank you @nmunro . The reason why there were two sketches beacuse I tested the code for both simple  and a bit complex one.
I also tested your code, looks like the iteration doesnt work because it only created one workpoint. But this is close to what Im looking for.
Message 4 of 9
JhoelForshav
JhoelForshav
@Anonymous
The code stops when one point has been created due to this portion of the code
   Exit For
End If
Just remove that and it will keep going 🙂
@Anonymous
   Exit For
End If
Message 5 of 9
JhoelForshav
in reply to: JhoelForshav
JhoelForshav
@Anonymous
Looking at this I just realized that some curves in a 3D-sketch could intersect the plane multiple times... an arc for example. So calculating each intersection point with transientgeometry and using those as proximitypoints for AddByCurveAndEntity could be a good idea 🙂
See attached ipt.
Dim oDoc As PartDocument = ThisDoc.Document
Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
Dim oSketch As Sketch3D = oDef.Sketches3D("3D Sketch1") 'Name of 3D-sketch
Dim oPlane As WorkPlane = oDef.WorkPlanes("XZ Plane") 'Name of plane
For Each oEnt As SketchEntity3D In oSketch.SketchEntities3D
	Try
	For Each oPoint As Point In oPlane.Plane.IntersectWithCurve(oEnt.Geometry)
		oDef.WorkPoints.AddByCurveAndEntity(oEnt, oPlane, oPoint)
	Next
	Catch
	End Try
Next
@Anonymous
See attached ipt.
	Try
	Next
	Catch
	End Try
Next
Message 6 of 9
Stakin
Stakin
Perfect.efore
before
after running:
Perfect.efore
before
after running:
Message 7 of 9
@JhoelForshav  Thank you.
Is it possible to first sort the transient geometry (points) by their x positions before it gets finally generated? Let's say whichever the closest to origin, should be generated first.
In that way, the indices are sorted already. The purpose is to create a sketch3d line using those points
Message 8 of 9
JhoelForshav
JhoelForshav
Hi @Anonymous
You could add the each Point and SketchEntity to a dictionary, then sort that dictionary with respect to the points distance to the origin. Then traverse that dictionary using the KeyValuePairs of Point, SketchEntity to create the workpoints. Like this 🙂
'---You might need these lines, I don't think so though---
'AddReference "System.Linq"
'Imports System.Linq
'Create a dictionary of Point, SketchEntity
Dim oDict As New Dictionary(Of Point, SketchEntity3D)
	Try
			'Add the Point and SketchEntity to the dictionary
			oDict.Add(oPoint, oEnt)
		Next
	Catch
	End Try
Next
'Sort the dictionary with respect to the distance to origin
Dim oOrigin As Point = ThisApplication.TransientGeometry.CreatePoint() 'No arguments = 0,0,0
Dim sorted = From pair In oDict
Order By pair.Key.DistanceTo(oOrigin)
oDict = sorted.ToDictionary(Function(p) p.Key, Function(p) p.Value)
'Create the points from the sorted dictionary
For Each oPair As KeyValuePair(Of Point, SketchEntity3D) In oDict
oDef.WorkPoints.AddByCurveAndEntity(oPair.Value, oPlane, oPair.Key)
Next
Hi @Anonymous
	Try
		Next
	Catch
	End Try
Next
Next
Message 9 of 9
JhoelForshav
JhoelForshav
Sorry, I just saw that you wrote that you only wanted to use the points X-value. The previous code sorts on distance to origin for the entire point. This sorts with respect to the points absolute X-value (meaning X closest to 0 in this case)
	Try
		Next
	Catch
	End Try
Next
'Sort the dictionary with respect to the X-value closest to 0
Order By Abs(pair.Key.X)
Next
	Try
		Next
	Catch
	End Try
Next
Next
