Working with Assembly Design View Representation
JBerns
Advisor Advisor
Message 1 of 9
JBerns
Community,
I am developing code (VBA) that will create drawing views from assembly Design View Representations (DVRs).
Using this code, I can get the count and names of the DVRs:
Public Sub ListDesignViewReps()
    Dim oView As Inventor.DesignViewRepresentation
    Dim oCompDef As ComponentDefinition
    Set oCompDef = ThisApplication.ActiveDocument.ComponentDefinition
    MsgBox ("Number of DVRs: " & oCompDef.RepresentationsManager.DesignViewRepresentations.Count)
    For Each oView In oCompDef.RepresentationsManager.DesignViewRepresentations
        MsgBox ("DVR Name: " & oView.Name)
    Next
End Sub
However, if the Master DVR is active, the number of DVRs reported is Actual + 1.
For example, an assembly with a Master and Default DVR will report a count of 3 and Master is listed twice.
If Default is active, the count reports as 2 and Master is listed only once.
Can anyone explain why having the Master DVR active changes the actual count?
I can likely workaround this issue, but I found it confusing. I have not tested with Pos Reps or LODs.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Replies (8)
Message 2 of 9
Sergio.D.Suárez
Hi, I really don't know why this error appears. I can only suggest you avoid it.
Then I share a VBA code that may solve this problem.
    Dim oActiveDVR As Inventor.DesignViewRepresentation
    Set oActiveDVR = oCompDef.RepresentationsManager.ActiveDesignViewRepresentation
    Dim j As Integer, i As Integer
    j = 0
    If oActiveDVR.Name = "Master" Then j = 1
    MsgBox ("Number of DVRs: " & oCompDef.RepresentationsManager.DesignViewRepresentations.Count - j)
   For i = 1 To oCompDef.RepresentationsManager.DesignViewRepresentations.Count - j
        Set oView = oCompDef.RepresentationsManager.DesignViewRepresentations(i)
        oView.Activate
    Next
End Sub
I hope I can be useful. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 9
JBerns
@Sergio.D.Suárez,
It is a peculiar behavior. I was able to test Pos Reps and LODs. Neither of these exhibit the varying count behavior as the DVRs.
My plan is to filter for specifically named DVRs, so I should be able to avoid the issue with the Master DVR. Thank you for the code though.
Next, I need to code to create a new drawing from an assembly and then a sufficient number of sheets based on the number of DVRs.
Jerry
CAD Administrator
Message 4 of 9
HideoYamada
This code may not work properly in Non-English environments.
I have run this test code in Inventor with Japanese language pack,
Sub test()
    Dim rm As RepresentationsManager
    Set rm = ThisApplication.ActiveDocument.ComponentDefinition.RepresentationsManager
    Debug.Print "Name  : " & rm.ActiveDesignViewRepresentation.Name
    Debug.Print "Test1 : " & (rm.ActiveDesignViewRepresentation.Name = "Master")
    Debug.Print "Test2 : " & (rm.ActiveDesignViewRepresentation.Name = rm.DesignViewRepresentations(1).Name)
    Debug.Print "Test3 : " & (rm.ActiveDesignViewRepresentation.DesignViewType = kTransientDesignViewType)
End Sub
and got the result as below.
Test1 : False
Test2 : True
Test3 : True
The name "マスター" means "Master" in Japanese.
I don't understand exactly what kTransientDesignViewType means, but Test3 seems to work fine.
I hope this helps you.
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Message 5 of 9
fransoze
You have 3 DVR because "Master" view is active and "Master" view is locked so Inventor make a transient view.
If you locked "view1" and activate this, you have 3 DVR too.
You must filter with DesignViewType :
        - kTransientDesignViewType ==> Create if active view is locked
        - kMasterDesignViewType ==> For Master view
        - kPublicDesignViewType ==> For all other views
Regards
François
Message 6 of 9
k14348
  While run this script if active design view rep is in locked condition it will be counted as 2. That particular rep will be counted as 2. Except master others should be unlocked condition. better before you count unlock all rep and active default view rep then start count. Hope this will help.
Karth
Message 7 of 9
k14348
Hope this script solves your prob.
Option Explicit
Public Sub DesignViewRep()
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
    Dim oRepMgr As RepresentationsManager
    Set oRepMgr = oAsmDoc.ComponentDefinition.RepresentationsManager
    Dim oDVRs As DesignViewRepresentations
    Set oDVRs = oRepMgr.DesignViewRepresentations
    Dim oDVR As DesignViewRepresentation
    For Each oDVR In oDVRs
        On Error Resume Next
        oDVR.Locked = False
    Next
    oDVRs.Item("Default").Activate
    MsgBox ("Total No. of DVRs: " & oDVRs.Count)
        MsgBox ("DVR Name: " & oDVR.Name)
    Next
End Sub
Karth
Message 8 of 9
JBerns
@HideoYamada / @fransoze / @k14348 ,
Thank you all for the information, explanations, and code. I look forward to using these solutions.
Jerry
CAD Administrator
Message 9 of 9
vinayababu.yerneni
Good and clear explanation, it helped me, Thanks!
