Link/load parameters from other part using ilogic
I want to Link/load parameters from other part, if i use below iLogic it shows error (refer attachment). can anyone help me to solve this problem.
If Parameter("C:\Inventor_DATA_2\part_01.ipt", "Li_length_with_TF") > 1000 Then
Feature.IsActive("Lofted Flange3") =False
Sergio.D.Suárez
Hi, this could be an alternative way to access a parameter from another file. I have placed a message box for you to check the units before generating equality. Because the internal unit of Inventor is "cm".
The rule defines the external document, opens it in hidden mode and accesses its parameters. Then start the equality and finally close the open document in hidden mode .. Greetings
I hope the rule works and is useful
Dim oDoc As Document = ThisApplication.Documents.Open("C:\Inventor_DATA_2\part_01.ipt", False)
Param = oDoc.componentdefinition.parameters("Li_length_with_TF")
MessageBox.Show(Param.value)
If Param.Value > 1000 Then
oDoc.Close
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Sergio.D.Suárez
oDoc.Close
Once the values have been checked you can delete the message box.
I hope the rule works and is useful. Greetings
Mechanical Designer
Hello @Sergio.D.Suárez ,
Thank you its working fine.
