Where can I find the ControlDefinitions Cmd list in Red String?
1 REPLY 1
Stakin
941 Views, 1 Reply
1 REPLY 1
jdkriek
in reply to: Stakin
Here's VBA from Brian Ekins - that will loop through all the Definitions and write to .txt file.
Sub PrintCommandNames()
    ' Get the CommandManager object.
    Dim oCommandMgr As CommandManager
    Set oCommandMgr = ThisApplication.CommandManager
    ' Get the collection of control definitions.
    Dim oControlDefs As ControlDefinitions
    Set oControlDefs = oCommandMgr.ControlDefinitions
    ' Open the file and print out a header line.
    Dim oControlDef As ControlDefinition
    Open "C:\temp\CommandNames.txt" For Output As #1
    Print #1, Tab(10); "Command Name"; Tab(75); _
              "Description"; vbNewLine
    ' Iterate through the controls and write out the name.
    For Each oControlDef In oControlDefs
        Print #1, oControlDef.InternalName; Tab(55); _
                  oControlDef.DescriptionText
    Next
    ' Close the file.
    Close #1
End Sub
My iLogic isn't as elegantly formatted in the .txt file, but it works for me
Dim sPath As String = "C:\temp\CommandNames.txt"
Dim oCommandMgr As CommandManager = ThisApplication.CommandManager
Dim oControlDefs As ControlDefinitions = oCommandMgr.ControlDefinitions
	If System.IO.File.Exists(sPath) = True Then
		Dim objWriter As New System.IO.StreamWriter(sPath)
		objWriter.WriteLine(oControlDef.InternalName & " | | " & oControlDef.DescriptionText)
			Next
		objWriter.Close()
		MsgBox("List Written to File")
	Else
		MsgBox("File Does Not Exist")
	End If
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
