Thanks but I don't want to view DWF files, but IPTs, IAMs and IDWs.
Pretty much in the way Voloview itself can do it.
Thanks anyway!
"Charles Bliss" wrote in message
news:3C7B25CF.3615D711@cbliss.com...
> I would venture that the answer might lie in the C++ source code which is
> installed with Inventor. Look at the sample files under C++ / Viewer.
> Patrick de Stobbeleir wrote:
> > Alain,
> > I think the problem is the Inventor Drawing, because it is a
hybrid/metafile
> > file with both Inventor Drawing data and an "embedded" DWF file. To get
> > VoloView to read the DWF part of the file it has to be extracted in some
way
> > or directed to read from a specific point of the file (reverse
engineering
> > or with the help from AutoDesk), this will take some time to find out
how
> > the DWF is stored and even compressed in a idw file.
> > -Patrick
> > "alain" wrote in message
> > news:BBF2EFAABD38B96E2661A98EA36FFAF9@in.WebX.maYIadrTaRb...
> > > Hi all.
> > > I'm trying to use the Voloview control in a VB application I'm doing
and
> > I'm
> > > experiencing some troubles: If I assign a DWG file to the voloview
> > control,
> > > it displays it without pb. But if I assign IV files, nothing is
> > displayed.
> > > Now I noticed there are two empty settings I might have to fill:
"Support
> > > path" and "Font path". these are empty for now since I don't really
know
> > > what to put in there.
> > > So if one of you knows what I'm doing wrong, I'll be glad to hear from
> > you!
> > > Thanks.
> > > Alain
