Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Visual studio program. withevent documentchange
9 REPLIES 9
Message 1 of 10
TechInventor20
472 Views, 9 Replies
TechInventor20
Goodmorning,
We got a standalone program at work for inventor. In the program we can do different things with inventor. But the one thing we need is to get the name of the active document without having to click at a button or something. I can't get it to work. The current code is this:
Public Class Form5
    Private WithEvents m_onDocumentChangeEvent As Inventor.ApplicationEvents
    Private WithEvents m_appEvents As Inventor.ApplicationEvents
    Private g_inventorApplication As Inventor.Application
    Private DocumentObject As Inventor.Document
    Public Sub ActiveEvents()
        g_inventorApplication = Marshal.GetActiveObject("Inventor.Application")
        DocumentObject = g_inventorApplication.ActiveDocument
        m_onDocumentChangeEvent = g_inventorApplication.ApplicationEvents
        m_appEvents = g_inventorApplication.ApplicationEvents
    End Sub
    Private Sub m_onDocumentChangeEvent_OnDocumentChange(ByVal DocumentObject As Inventor.Document,
                                                     ByVal BeforeOrAfter As EventTimingEnum,
                                                     ByVal ReasonsForChange As CommandTypesEnum,
                                                     ByVal Context As NameValueMap,
                                                     ByRef HandlingCode As HandlingCodeEnum) Handles m_onDocumentChangeEvent.OnDocumentChange
        If BeforeOrAfter = EventTimingEnum.kAfter Then
            MsgBox("OnActivateDocument " & DocumentObject.DisplayName)
        End If
        Label1.Text = "Inventor document name"
    End Sub
End Class
Is it possible to change the label name when I change the the document"??
Goodmorning,
Public Class Form5
    End Sub
        End If
    End Sub
End Class
9 REPLIES 9
Message 2 of 10
CattabianiI
Have you debugged this code? Does it stop in the event handler?
OnDocumentChange fires when a document has a change, which means a parameter modification, a feature modification and so on.
Maybe what you need is OnActivateDocument?
Message 3 of 10
TechInventor20
Thank you for the reply.
I did what you suggested but now I cant even debug the program. I get this error message at
OnDocumentChange
Do you know what i do wrong?
OnDocumentChange
Message 4 of 10
CattabianiI
OnDocumentChange and OnActivateDocument have two different signatures (number and type of arguments of the event handler), check the sintax in the manual I linked in the previous message.
Message 5 of 10
TechInventor20
I can debug the program, but when I'm in the Form and I change files inside inventor it doesn't work. It doesn't trigger the code. What am I doing wrong? Or is this not the code for the job?
Message 6 of 10
CattabianiI
Who is calling ActiveEvents method? can you debug that method?
Changing files means switch the active document or make a modification on a document?
Message 7 of 10
TechInventor20
Yes, I got it to work.
Just need to call the ActiveEvents...
I need to know when it changes the document. then I get some properties from the part, assembly or drawing.
Thank you for helping!
Message 8 of 10
TechInventor20
Got another question. The following code isn't working...
    End Sub
    Private Sub m_onDocumentChangeEvent_OnActivateDocument(ByVal DocumentObject As Inventor.Document,
                                                     ByVal Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum) Handles m_onDocumentChangeEvent.OnActivateDocument
            If _invApp.ActiveDocument.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
                If BackgroundWorker3.IsBusy <> True Then
                    BackgroundWorker3.RunWorkerAsync()
                End If
            End If
        End If
    End Sub
    Private Sub BackgroundWorker3_DoWork(sender As Object, e As DoWorkEventArgs) Handles BackgroundWorker3.DoWork
'some code
    End Sub
    Private Sub backgroundWorker3_RunWorkerCompleted(ByVal sender As System.Object, ByVal e As RunWorkerCompletedEventArgs) Handles BackgroundWorker3.RunWorkerCompleted
        Dim drawingdoc As DrawingDocument
        drawingdoc = _invApp.ActiveDocument
        Dim labeltext As String
        labeltext = drawingdoc.DisplayName
        'MsgBox(labeltext)
        Label24.Text = labeltext
end sub
the part where it go's wrong is when i give Label24.text a new name. I get this error message.
    End Sub
                End If
            End If
        End If
    End Sub
'some code
    End Sub
        'MsgBox(labeltext)
end sub
Message 9 of 10
CattabianiI
RunWorkerAsync in that event handler without await, updating somthing in the UI thread; this could be really painful: is it really necessary? The exception seems to talk about threads, right?
I think here is more about threads in .NET and the web has plenty of Q&A about this matter, than Inventor related things.
Message 10 of 10
TechInventor20
I fixed it with the
Control.CheckForIllegalCrossThreadCalls = False
code
I fixed it with the
code
