Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Verify A Part Has A Drawing
12 REPLIES 12
Message 1 of 13
harvey3ELEA
547 Views, 12 Replies
Greetings,
Anyone here have a code available that can be added to populate a parts list with a "Y" or "N" to verify if a part in an assembly has an existing drawing in the current project folder?
Typically, we have drawings for our manufactured parts (but not all of them currently), and no drawings for purchased parts.
My parts list contains the typical columns like "Item", "Part #", "Qty", "Description", etc, but I'd like to have an automated "DWG" column that self-populates when Inventor determines that a drawing exists for the individual parts in that parts list like shown in the picture.
Thanks, Harvey
12 REPLIES 12
Message 2 of 13
Frederick_Law
in reply to: harvey3ELEA
The only way to find drawings is search EVERY folders in Workspace.
EVERY time the drawing is updated.
Still it won't know if the drawing is deleted after.
Message 3 of 13
WCrihfield
Hi @harvey3ELEA.  If all your drawings are in the same exact folder as the model file they are documenting, and the drawing file is named exactly the same as the model file, just with the different file extension, then that would make a process like this much easier to manage.  However, it can still be a pretty inaccurate process.  There is no 'link' added to a model file that says it has had a drawing made for it.  Only the drawing document will know which model files are being referenced within it.
With that in mind, a better long term process might be to have some code that runs when you save any drawings, and in that code, have it inspect the model documents being referenced within the views of the drawing, then write something into those model documents, such as a custom iProperty, about the drawing.  This code could be an external rule, or some other type of external tool, so that it could be ran on older drawings too, at some point.  Then all new drawings, and all drawings that get edited and saved, will be writing this wanted data back into the models.  Then those models will contain something (possibly a custom iProperty) that can be used for your PartsList column.  It would take a while to build up that system though.
Wesley Crihfield
(Not an Autodesk Employee)
Message 4 of 13
WCrihfield
Another thought that comes to mind is that if you use Vault, then you may be able to use that somehow to find if a model has a drawing.  I have not used Vault yet myself though, so I would not know how to get that information from Vault by code.  A potential problem with using Vault for this, is that it may only find every drawing that references that model, at any level.  So, if the model is a part, and it is being used in 25 assemblies, and those 25 assemblies all have drawings, it may find all those in its search.  Not sure if Vault can limit a search like that to only 'directly references', and not referencing indirectly.  Just another thought that might be explored.
Wesley Crihfield
Message 5 of 13
harvey3ELEA
Frederick, while I won't say never, we likely won't delete any drawings, just change or obsolete them into a separate folder.
Wesley, we don't use Vault here at work (I'm not sad about that), and I simply don't know where to take this issue going forward.  If you have any ilogic coding that could start me off in the right direction, I'm willing to take a crack at tweaking it to the best of my ability to see what results I can achieve.  If not, no problem....I'd resort to just doing the manual entry to have something available for the shop guys.
Message 6 of 13
Frederick_Law
Since you know which part should have drawing, set it up on the model.
The property "DWG" should be in the part/assembly.
Whoever make drawing will update the model with "Y".
Drawing partlist will update with the model.
Message 7 of 13
harvey3ELEA
Frederick, that will work, but we have a lot of legacy parts that never had drawings made for a variety of reasons.
Setting it up in the model is workable, but it's still a manual process.  I'd rather see if Inventor can determine if a drawing already exists, and if not, place an "N" on the parts list.......which would also notify me that a drawing needs to be made.
Message 8 of 13
Hi @harvey3ELEA
Can the path to your drawings be deduced from the model path?
If you can predict the path, then we could write a routine to process the assembly that the parts list is pointing to and write a custom iProperty to each component that records the Y or N, and then that iprop can be shown in the parts list.
Meaning something like this where we can know that changing the extension points us to the drawing:
  • I:\Engineering\Inventor\Designs\7771\7771-01.ipt
  • I:\Engineering\Inventor\Designs\7771\7771-01.idw
Or something like this where we can know that changing the extension and looking in a known, standard folder points us to the drawing:
  • I:\Engineering\Inventor\Designs\7771\Models\7771-01.ipt
  • I:\Engineering\Inventor\Designs\7771\Drawings\7771-01.idw
Message 9 of 13
Curtis,
Yes to your question.  We keep parts, assemblies, sub-assemblies, and their respective drawings pathed to the same folder.  Some sort of ilogic routine to look for an .idw in the same project folder would work very well in this case, in my opinion.
Unfortunately, I am not a competent ilogic code creator, but I have had some success modifying them to suit my needs.
If you're willing, I'd love to see what you come up with...
Thanks, Harvey
Message 10 of 13
Hi @harvey3ELEA
Give this example a try. It doesn't actually write down to the models, but maybe writing to the parts list is all that is needed?
I hope this helps.
Curtis
Sub Main
	Dim oDrawDoc As Document = ThisApplication.ActiveDocument
	Dim oSheet As Sheet = oDrawDoc.ActiveSheet
	Dim oPartList As PartsList
	Try
		oPartList = oDrawDoc.ActiveSheet.PartsLists.Item(1)
	Catch
		MsgBox("no parts list found on active sheet", , "iLogic")
		Exit Sub
	End Try
	For Each oPartListRow In oPartList.PartsListRows
		Dim hasDWG As String = "N" 'set default
		If oPartListRow.Visible = False Then Continue For
		Dim oBomRow As DrawingBOMRow = oPartListRow.ReferencedRows.Item(1)
		Dim oRefDoc As Document = oBomRow.BOMRow.ComponentDefinitions.Item(1).Document
		Dim oCell As PartsListCell
		oFilePath = oRefDoc.FullFileName()
		oDrawingFilePath = Left(oFilePath, Len(oFilePath) -3) & "idw"
		If System.IO.File.Exists(oDrawingFilePath) = True Then hasDWG = "Y"
		'find the cell using the row and the column name
		Try
			oCell = oPartListRow.Item("DWG")
		Catch
			MsgBox("Parts list does not contain a column called DWG", , "iLogic")
			Exit Sub
		End Try
		oCell.value = hasDWG
	Next
End Sub
Message 11 of 13
Curtis, that little gem runs beautifully!  Thank you very much for that little trick which will now tell me and my shop guys what drawings are missing, need to be made for legacy parts, and which drawing they'll know they can pull up on their tablets during production.
One suggestion if you feel like tweaking it:  is there a way for this code to add a "DWG" column automatically?  If not, it's no big deal to manually add that in prior to running the code.
Thanks again!  Harvey
Message 12 of 13
Hi @harvey3ELEA ,
Glad that worked. I meant to look into adding the column, but got distracted earlier and forgot.
See this version, it will always add it to the end of the parts lists columns.
I hope this helps.
Curtis
Sub Main
	Try
	Catch
		Exit Sub
	End Try
		Try
			oRefDoc = oBomRow.BOMRow.ComponentDefinitions.Item(1).Document
		Catch
			Continue For
		End Try
		Try
		Catch
			oColumn = oPartList.PartsListColumns.Add(PropertyTypeEnum.kCustomProperty, , "DWG", 0)
		End Try
		oCell.Value = hasDWG
	Next
End Sub
Message 13 of 13
harvey3ELEA
Curtis, that's a homerun!  A truly useful routine that helps to streamline our files and shop processes.
I simply run a column adjuster code after yours to get the best fit on the drawing.
