Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Vba Matchcrop rule
2 REPLIES 2
253 Views, 2 Replies
Vba Matchcrop rule
This Vba code works great with line MsgBox ("Matchcrop") but if i remove the line the code doesn't work.
Can anyone help with this??
Sub MatchCrop_MA()
On Error Resume Next
Dim odoc As Document
Set odoc = ThisApplication.ActiveDocument
oSelectedPriority = odoc.SelectionPriority
odoc.SelectionPriority = kEdgeSelectionPriority
odoc.Update2 (True)
ThisApplication.CommandManager.ControlDefinitions.Item("AppRefreshCmd").Execute2 (True)
Set oitem1 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllEntitiesFilter, "Select first line")
If oitem1 Is Nothing Then
odoc.SelectionPriority = oSelectedPriority
Exit Sub
End If
again:
Set oitem2 = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllEntitiesFilter, "Select second line")
If oitem2 Is Nothing Then
Exit Sub
End If
oitem2.Layer = oitem1.Layer
GoTo again
End Sub
2 REPLIES 2
tobias.orlow
Hi vulic,
The code works as expected on my side, also without the MessageBox. What exactly is not working on your side if you remove the MessageBox?
Which version of Inventor are you working on?
Many thanks,
Tobias
Tobias Orlow
Designated Support Specialist
Customer Success Organization
Linkedin: www.linkedin.com/in/tobiasorlow/
My firm stayed at Autodesk® Inventor® 2018
