VBA Marco background color
Darkforce_the_ilogic_guy
Advisor Advisor
Message 1 of 8
I want to make a marco that chance between 2 background color
I want it to run this code if the ColorSchemes is not Millennum
ThisApplication.ColorSchemes.Item("Millennium").Activate
        ThisApplication.ColorSchemes.BackgroundType = BackgroundTypeEnum.kImageBackgroundType
I want it to run this code if the ColorSchemes is not Presentation
ThisApplication.ColorSchemes.Item("Presentation").Activate
        ThisApplication.ColorSchemes.BackgroundType = 52737
And I only what to want to run the marco to make it happen ... .no dialog Box please
I got code form a coworker. but that force me to make the chose ... I want it to do it for me by reading what background is aktiv before hitting the marco. can you help
Replies (7)
Message 2 of 8
pball
I can't find a way to get the active color scheme so this isn't ideal but it seems to work. It is possible get the current value for the background type so a simple check of the current value lets you toggle the two color schemes.
    If (ThisApplication.ColorSchemes.BackgroundType = 52737) Then
    Else
    End If
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
Userscript to edit forum links to jump to first unread post
Jump To First Post Userscript
Message 3 of 8
aurel_e
Hi all,
I am using this code copied from this discussion(Inventor 2018):
Sub ChangeBackground()
        ThisApplication.ColorSchemes.Item("High Contrast").Activate
    Else
        ThisApplication.ColorSchemes.Item("Sky").Activate
    End If
End Sub
The problem is that I want to switch from a "Sky" color scheme with the "Background Image" (please see screenshot attached) and the macro is giving me a normal blu background. I don't know how to write it.
Message 4 of 8
    Else
is this what your want?
End If End Sub
Message 5 of 8
aurel_e
nearly there:
I'm using this now (trying to understand and messing around):
If (ThisApplication.ColorSchemes.BackgroundType <> kImageBackgroundType) And (ThisApplication.ColorSchemes.BackgroundType <> 52737) Then
        Else
    Else
    End If
    End If
End Sub
I don't like this 2 lines:
What I'm tryoing to say is : If the color scheme is neither Sky or High Contrast, activate "Sky".
Thanks.
Message 6 of 8
This is all your need I think..
Public Sub ChangeBackground()
If ThisApplication.ActiveColorScheme.Name = "High Contrast" Then
Stop
If ThisApplication.ActiveColorScheme.Name = "Sky" Then
Stop
Else
End If
End If
End Sub
Message 7 of 8
aurel_e
Hi BT,
the "stop" for same reason is not working.
I have changed it in:
Else
Else
End If
End If
End Sub
This is now fine!
Thank you for your support.
Message 8 of 8
Below is the code I use.  I use a grey gradient when I'm normally working, and then if I want to do a screenshot of something, I change the background to white.  Then I want to switch it back easily.  Only thing to note is the custom image file I made called "Plain white" and the folder location.  Edit those lines to match your setup.
Sub Background_Switch()
Dim oBackGroundType As BackgroundTypeEnum
With ThisApplication.ColorSchemes 'edit the application background settings easily
oBackGroundType = .BackgroundType
Dim oColorScheme As ColorScheme
Set oColorScheme = ThisApplication.ActiveColorScheme
If oBackGroundType = kGradientBackgroundType Then
oColorScheme.ImageFullFileName = "C:\Users\Public\Documents\Autodesk\Inventor 2019\Backgrounds\PLAIN WHITE.png"
Else
.BackgroundType = BackgroundTypeEnum.kGradientBackgroundType
End If
End With
End Sub
