Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
VBA: Having trouble assigning a variable string to SketchSymbolDefinition , getting type Mismatch
2 REPLIES 2
A.Acheson
408 Views, 2 Replies
A.Acheson
Having trouble assigning a variable string to SketchSymbolDefinition. This works fine in VB.NET.
Anyone know what is going wrong?
Public Sub addnote()
    Dim Notes As New ArrayList
    Notes.Add ("Note1")
    Notes.Add ("Note2")
    Notes.Add ("Note3")
    Dim oSketchedSymbol As SketchedSymbol
    Dim oSketchedSymbolDef As SketchedSymbolDefinition
    'This assumes a drawing document is active.
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument '  a reference to the drawing document.
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
    Dim oTG As TransientGeometry
    Set oTG = Inventor.ThisApplication.TransientGeometry
    For Each oName In Notes
         Debug.Print oName
         Set oSketchedSymbolDef = oDrawDoc.SketchedSymbolDefinitions(oName) ' Constant Integer or string works fine but string by variable is failing.
         Dim oTGPoint As Point2d
         Set oTGPoint = oTG.CreatePoint2d(0, 0)
        ' Add an instance of the sketched symbol definition to the sheet.
        Set oSketchedSymbol = oSheet.SketchedSymbols.Add(oSketchedSymbolDef, oTGPoint)
    Next
                'Call MoveNote(oDrawDoc, oSheet, oTG)
    End Sub
 From the API help
SketchedSymbolDefinitions.Item( Index As Variant ) As SketchedSymbolDefinition
IndexVariantInput Variant value that specifies the SketchedSymbolDefinition to return. This can be either a numeric value indicating the index of the item in the collection or it can be a string indicating the sketched symbol definition's name. If an out of range index or a name of a non-existent sketched symbol definition is specified, an error occurs.
Regards
Alan
    Notes.Add ("Note1")
    Notes.Add ("Note2")
    Notes.Add ("Note3")
    Dim oSheet As Sheet
         Debug.Print oName
    Next
    End Sub
 From the API help
Regards
Alan
Labels (1)
  • VBA
2 REPLIES 2
Michael.Navara
in reply to: A.Acheson
Michael.Navara
This is because your variable oName is Variant type in general. You need to cast its value to string and then it works
Sub GetSketchedSymbolByName()
    Dim drw As DrawingDocument
    Set drw = ThisApplication.ActiveDocument
    Dim names As New ArrayList
    Call names.Add("test")
    For Each name In names
        Debug.Print name
        'Doesn't work because name is Variant in general
        'Set sDef1 = drw.SketchedSymbolDefinitions(name)
        Dim defName As String
        defName = name
        Set sDef2 = drw.SketchedSymbolDefinitions(defName)
        Debug.Print "RESULT: " & sDef2.name
    Next
End Sub
        Debug.Print name
        defName = name
    Next
End Sub
A.Acheson
in reply to: Michael.Navara
A.Acheson
Thanks for the confirmation and solution Michael. I was there when I was testing and had read about needing to change to a string but hadn't implemented correctly. VB.NET is more forgiving on these little details.
Regards
Alan
Regards
Alan
