VBA: adding a reference to Microsoft VBA Extensibility
itUMLAN
itUMLAN
I want to compare the actual source code of two .ivb files. Since they are binary, What should do the trick is exporting all files in my .ivb: https://stackoverflow.com/questions/39293881/code-compare-for-vba-source-code
However, it says to "add a reference to Microsoft Visual Basic for Applications Extensibility 5.3."
How do I do this exaclty?
the closest thing I've come to find is this for Excel: http://www.exceltoolset.com/setting-a-reference-to-the-vba-extensibility-library-by-code/
but it doesn't seem to be working for Inventor.
udo.huebner
Autodesk Support
Autodesk Support
You want to know how to exactly add a reference to "Microsoft Visual Basic for Applications Extensibility 5.3" ?
1. Start Inventor and then start VBA Environment using ALT+11
2. Add Reference
By the way, the linked code from https://stackoverflow.com/questions/39293881/code-compare-for-vba-source-code is intended to use with AutoCAD
udo.huebner
Autodesk Support
Autodesk Support
If you change
Set vbe = ThisDrawing.Application.vbe
to
Set vbe = ThisApplication.vbe
in Inventor, the linked code above works as expected.
Jon.Dean
Hi @itUMLAN ,
This forum thread was escalated to Autodesk Technical Support but I see Udo has answered your question in the forum.
Do you need further help or did Udo's answer to you, help you resolve this issue?
Cheers
Jon.
Jon Dean
itUMLAN
@Jon.Dean I misclicked on the support button, and I could not undo it. Thank you for checking it.
@udo.huebnerthank you for the solution ! It works. Brillliant, we have been looking for this for a long time.
