VB.net Output combobox value to inventor Model parameters
BromanSillito
Message 1 of 9
BromanSillito
Hey,
I'm creating a form in VB.net that controls parameters in an Inventor 3D model. Here is the sub routine I am using to pass the parameters:
Public Sub ChangeParameter(paramName As String, setValue As Double)
'Make Sure Inventor is Running
CheckInventor()
Try
'set the flag to false
Dim paramFound As Boolean = False
Dim oParameter As Parameter = Nothing
Dim oParameters As Inventor.Parameters = oInventorApp.ActiveDocument.ComponentDefinition.Parameters
'loop through all of the parameters
For Each oParameter In oParameters
If UCase(paramName) = UCase(oParameter.Name) Then
'set the flag
paramFound = True
'change the parameter and make sure it is specified in inches
oParameter.Expression = System.Convert.ToString(setValue) & " in"
'update the drawing
oInventorApp.ActiveDocument.Update()
'since the parameter was found, exit the loop
Exit For
End If
Next
'alert the user if the specified parameter was not found
If paramFound = False Then
Beep()
MsgBox("Parameter name: " & paramName & " was not found.", vbOKOnly, "Parameter not found")
End If
Catch ex As Exception
'alert the user if there is a problem
MsgBox(ex.Message & -"Error: ChangeParameter")
End Try
End Sub
I am accessing the sub-routine from the form using the following:
Private Sub cboChmbrSzChmbr_SelectedIndexChanged(sender As Object, e As EventArgs) Handles cboChmbrSzChmbr.SelectedIndexChanged
'Update Chamber Size in Inventor
CheckInventor()
ChangeParameter("SHELL_PIPE_SIZE", cboChmbrSzChmbr.SelectedItem)
End Sub
Here is the sub used to check if Inventor is open:
Public Sub CheckInventor()
oInventorApp = GetObject(, "Inventor.Application")
If Err.Number Then
MsgBox("Inventor must be running.")
End
End If
If oInventorApp.Documents.Count = 0 Then
MsgBox("An assembly document must be active.")
End
End If
'if you get to this point, then make the active document the
'oassemblyDocument
oAssemblyDocument = oInventorApp.ActiveDocument
However, I get the following error when I run the program & select an item from the cboChmbrSzChmbr combobox:
Can anyone help me out with this?
Replies (8)
Message 2 of 9
ekinsb
The problem is that the value you're getting back from the cboChmbrSzChmbr.SelectedItem call is a String and the setValue argument in your ChangeParameter Sub is typed as a Double.  You can also simplify how you find the parameter.  Below is a new version of your Sub.
    CheckInventor()
    Try
        Dim oParameters As Parameters = oInventorApp.ActiveDocument.ComponentDefinition.Parameters
        ' Get the parameter.
        Try
            oParameter = oParameters.Item(paramName)
            Beep()
            Return
        End Try
        ' Change the parameter using inches as the unit.
        oParameter.Expression = setValue & " in"
        'update the drawing
        MsgBox(ex.Message & " - Error: ChangeParameter")
    End Try
End Sub
Brian Ekins
Mod the Machine blog
Message 3 of 9
BromanSillito
Thank you for the response ekinsb! I tried replacing my code with the code that you posted & running the program, but now I get the following error when picking an item from the combobox:
Do you have any other thoughts?
Message 4 of 9
BromanSillito
I forgot to mention, the Model I am modifying is an Assembly document. Not sure if that helps.
Message 5 of 9
ekinsb
I was having a similar problem when I was first testing your code.  I couldn't see any problems and finally just retyped that line and then it worked.  I think maybe there is an invisible bad character somehow that's resulted from copying and pasting from the discussion group.
Try retyping the line below and see if that gets rid of the problem.
Dim oParameters As Parameters = oInventorApp.ActiveDocument.ComponentDefinition.Pa​rameters
Brian Ekins
Message 6 of 9
BromanSillito
Thank you again for the help, ekinsb. I retyped that line and even tried re-creating the whole module and re-typed everything in, but I the following error shows up now:
Do you have any ideas why?
Message 7 of 9
ekinsb
That's different than the previous error so I suspect what you did fixed that.  That error's getting displayed when anything wrong happens in that function so I don't know which line it's complaining about.  You can step through your code to see where it jumps to the catch handler.  Just put a break point at the top of that function and then run your program and once it hits the break point you can start stepping through a line at a time.
Brian Ekins
Message 8 of 9
BromanSillito
Okay, I tried stepping through it and this is where the error occurred:
One thing I hadn't realized is that the parameter in Inventor that I'm modifying is a "Text" parameter and it is unitless, so I modified the following parts of the code:
Public Sub ChangeParameter(paramName As String, setValue As String)
'and...
oParameter.Expression = setValue '& " in"
This produced the same errors as before, however.
Message 9 of 9
BromanSillito
Okay, after doing some searching on how to handle "Text" type properties, I found that I have to change this:
'Change the parameter using inches as the unit.
to this:
oParameter.Value =
This seems to fix the problem & update the Text parameter as desired. Thanks for all the help ekinsb!
