Hello I want to add some user parameters but if the parameter exists skip the creation of such parameters
My code is like this
Private Sub Button_Click(sender As Object, e As RoutedEventArgs)
Dim userParams As UserParameters = oPartDoc.ComponentDefinition.Parameters.UserParameters
Dim newParam As UserParameter ' Placeholder
Dim oFormat As CustomPropertyFormat
Dim oParam As Parameters
Dim oCantidad As String = cantidadTXTBox.Text
If oCantidad Is Nothing Then
MsgBox("Poner numero de piezas en textbox")
Exit Sub
'LENGTH
Try
oParam = oPartDoc.ComponentDefinition.Parameters.UserParameters("Cantidad")
Catch 'If the parameter was not found, then create a new one.
newParam = userParams.AddByExpression("Cantidad", oCantidad, "mm") ' Create the Parameter as per above
newParam.ExposedAsProperty = True 'Flag for Export
oFormat = newParam.CustomPropertyFormat 'For some reason or other this line is needed to enable the following formatting
oFormat.PropertyType = Inventor.CustomPropertyTypeEnum.kTextPropertyType
oFormat.Precision = Inventor.CustomPropertyPrecisionEnum.kZeroDecimalPlacePrecision 'Set one decimal place
'oFormat.Units="mm" 'Units
oFormat.ShowUnitsString = False
oFormat.ShowLeadingZeros = False
oFormat.ShowTrailingZeros = False
MsgBox("Cantidad agregada")
End Try
End Sub
but it creates the parameter if it doesent exist but if it exists it creates a nother one the try catch is not working.
"By the way is there another way to create parameters easier?.
thanks in advance
Solved by A.Acheson. Go to Solution.
Hi @j.romoYDW7Q
Your issue begins in the Try statement. oParam is declared as parameters collection so more than 1. Then in the try statement you set oParam as a single parameter. Silly Example userParams is the dozen eggs where as userParam is the egg.
Also you can be more precise and declare oParam as a userParameter
Incorrect
Try
Catch
End Try
Correct
Dim userParam As UserParameter ' Placeholder
Try
userParam = userParams.Item ("Cantidad")
userParam = userParams.AddByExpression("Cantidad", oCantidad, "mm") ' Create the
End Try
