Using iLogic to retrieve excel variables (price, cost) based on Part Numbers
26 REPLIES 26
Message 1 of 27
2138 Views, 26 Replies
Hello forum,
I've created a small program that does cost and pricing reports. I've been searching and trouble shooting a few lines of code that I have found on this forum (Thank you @Neuzzo for presenting the original bulk of the code). I had to modify the code to update the 'Estimated Cost' in iproperties of each part at the assembly level. But I've stitched up a few lines of code that worked for me when I'm running at the part level.
Now its a mess of code that doesn't work.
My code as it is right now:
Sub Main ()
'Create variables'set a reference to the assembly component definintion
Dim oAssDoc As AssemblyDocument = ThisApplication.ActiveDocument
'Dim ExcelFullName As String
'Dim FileName As String
Dim oFileDlg As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
oFileDlg.InitialDirectory = oOrigRefName
oFileDlg.CancelError = True
'oFileDlg.ShowOpen()
'If Err.Number <> 0 Then
'Return
'ElseIf oFileDlg.FileName <> "" Then
'ExcelFullName = oFileDlg.FileName
'End If
'Open Excel database
GoExcel.Open("\\SRV-DOC\company folder\program name\product family\pricing.xlsx", "sheet name")
'Iterate through each referenced document
'Dim oOcc As ComponentOccurrence
    For Each oDoc As Document In oAssDoc.AllReferencedDocuments
    ErHa = "Start"
    Try
        'Extract Part Number of active occurrence
        Dim oPropSet As PropertySet = oDoc.PropertySets.Item("Inventor User Defined Properties")
        oPartNumber = oDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
        'MessageBox.Show(oPartNumber)
    ErHa = "Define custom property collection"
	'Parameter.UpdateAfterChange = True
	'index row 5 through 100 or 150 or 10,000 (too long processing time)
	For rowPN = 5 To 60
	'find first empty cell in column A
	If (GoExcel.CellValue("A" & rowPN) = iProperties.Value(oPartNumber, "Part Number")) Then
	'find the price of the part using the part number
	oPrice = GoExcel.CellValue("L" & rowPN)
 	End If
	Next
	'MessageBox.Show(oPrice)
	iProperties.Value(oPartNumber, "Estimated Cost") = oPrice
Parameter.UpdateAfterChange = True i = GoExcel.FindRow("\\SRV-DOC\company folder\program name\product family\pricing.xlsx", "sheet name", "Part Number") '"=", oPartNumber) If i = "-1" GoTo oEnd End If Dim oPrice As String = GoExcel.CurrentRowValue("Price") If String.IsNullOrEmpty(oPrice) Then GetProperty(oPropSet, "Estimated Cost").Value = "" Else GetProperty(oPropSet, "Estimated Cost").Value = oPrice End If ErHa = "Update the file" iLogicVb.UpdateWhenDone = True Catch ex As Exception MsgBox("Part: " & oDoc.DisplayName & vbLf & "Code-Part: " & ErHa & vbLf & "Error: " & ex.Message) End Try oEnd: Next 'Close Excel database GoExcel.Close End Sub Private ErHa As String = vbNullString Function GetProperty(oPropset As PropertySet, iProName As String) As Inventor.Property ErHa = "GetProperty: " & iProName Dim iPro As Inventor.Property Try 'Attempt to get the iProperty from the document iPro = oPropset.Item(iProName) Catch 'Assume error means not found, so create it iPro = oPropset.Add("", iProName) End Try Return iPro End Function
Part numbers on my excel sheet are found on along the column A and begin on  A5 and its associated pricing are found under the column L.
The following iLogic code searches for the part number and its price:
	GoExcel.Open("\\SRV-DOC\MURAFLEX\CONFIGURATOR\MSD-M-B101-00\SAS-003X-01.xlsx", "SAS-003X-XX")
	For rowPN = 5 To 60
	End If
	Next
Then the code should match the part numbers on the excel sheet and return a price from excel:
	'iProperties.Value(oPartNumber, "Estimated Cost") = oPrice
        i = GoExcel.FindRow("\\SRV-DOC\MURAFLEX\CONFIGURATOR\MSD-M-B101-00\SAS-003X-01.xlsx", "SAS-003X-XX", "PART NUMBER") '"=", oPartNumber)
		'i = GoExcel.FindRow(ExcelFullName, "DISTINTA BASE", "Part Number", "=", oPartNumber)
		If i = "-1"
			GoTo oEnd
		End If
And then the price found in excel should update the iproperties value Estimated Cost
		Dim oPrice As String = GoExcel.CurrentRowValue("PRICE")
		'If String.IsNullOrEmpty(oCost) Then
        Else
		'GetProperty(oPropSet, "Estimated Cost").Value = oCost
		'GetProperty(oPropSet, "Tipo ricambio").Value = "C"
        End If
The problem is that whenever I run the iLogic code it doesn't update the Estimated Costs as expected and return an error.
Your help would be greatly appreciated by me and others that may benefit from this.
26 REPLIES 26
Message 21 of 27
WCrihfield
in reply to: WCrihfield
@Anonymous
It would look like this then:
iProperties.Value(oDoc, "Design Tracking Properties", "Cost") = oPrice
Wesley Crihfield
(Not an Autodesk Employee)
Message 22 of 27
Ok, so I applied the changes and I have the following code... I'm still not getting any value under Estimated Cost for each part in the assembly
		Dim oXLfile As String = "\\SRV-DOC\MURAFLEX\CONFIGURATOR\MSD-M-B101-00\SAS-003X-01.xlsx"
		Dim oSheet As String = "SAS-003X-XX"
		GoExcel.TitleRow = 2
		GoExcel.FindRowStart = 5
		Dim oRow As Integer = GoExcel.FindRow(oXLfile, oSheet, "PART NUMBER", "=", oPartNumber)
		Dim oPrice As Double = GoExcel.CurrentRowValue("PRICE")
        i = GoExcel.FindRow(ExcelFullName, "SAS-003X-XX", "PART NUMBER", "=", oPartNumber)
		If i = "-1"
			GoTo PROSSIMO
		End If
		Dim COSTO As String = GoExcel.CurrentRowValue("PRICE")
        If String.IsNullOrEmpty(COSTO) Then
        GetProperty(oPropSet, "Cost").Value = ""
        Else
        GetProperty(oPropSet, "Cost").Value = COSTO
        End If
I have changed Estimated Cost to Cost, but still not getting any dollar value for each part.
Message 23 of 27
WCrihfield
I don't think you would need to open each document before trying to modify their iProperties, because they are all being referenced by the assembly, but you could try using this line right after your initial For Each oDoc loop, just in case it makes a difference for you:
ThisApplication.Documents.Open(oDoc.FullFileName,False)
Then after you've assigned a value to its iProperties, try oDoc.Save, before you do the oDoc.Update.
Wesley Crihfield
Message 24 of 27
I've been trying multiple things to get this to work... I can't seem to get the Estimate Cost to update.
My current code:
Sub Main ()
oFileDlg.ShowOpen()
Return
ElseIf oFileDlg.FileName <> "SRV-DOC\company folder\program name\product family\pricing.xlsx" Then
End If
GoExcel.Open(ExcelFullName,"Sheet1")
'Iterate through each referenced document'Dim oOcc As ComponentOccurrence
    ErHa = "Start"
    Try
		Dim oXLfile As String = "SRV-DOC\company folder\program name\product family\pricing.xlsx"
		Dim oSheet As String = "Sheet1"
        i = GoExcel.FindRow(oXLfile, oSheet, "PART NUMBER", "=", oPartNumber)
		If i = "-1"
		GoTo LAST
		End If
		Dim oCost As String = GoExcel.CurrentRowValue("PRICE")
        Else
        GetProperty(oPropSet, "Cost").Value = oCost
        End If
		oDoc.Save
    End Try
LAST:
    Next
GoExcel.Close
End Sub
    Try
    Catch
    End Try
    Return iPro
End Function
The value I want this to return and update...:
The estimated costs...
Message 25 of 27
WCrihfield
Try this code:
It bypasses the whole dialog box part and the whole 'GetProperty' function.  Then it defines the property set right up front (because it is always there).  I think you may have been trying to get the property from the wrong property set.  The "Cost" property is not in the "Inventor User Defined Properties" set, it's in the "Design Tracking Properties" set.
Dim oXLfile As String = "\\SRV-DOC\company folder\program name\product family\pricing.xlsx"
	GoExcel.Open(oXLfile,oSheet)
			Dim oProjProps As PropertySet = oDoc.PropertySets.Item("Design Tracking Properties")
	        oPartNumber = oProjProps.Item("Part Number").Value
			If GoExcel.CurrentRowValue("PRICE") Is Nothing Then Resume Next
			oProjProps.Item("Cost").Value = oPrice
			oDoc.Save
    Next
GoExcel.Close
Wesley Crihfield
Message 26 of 27
WCrihfield
@Anonymous
Or if you want to keep the iProperty overwrite in place that overwrites the Cost value to nothing when the Excel cell for cost if blank, then you can probably do it this way.
				oProjProps.Item("Cost").Value = 0
				Resume Next
			End If
			oDoc.Save
    Next
GoExcel.Close
Wesley Crihfield
Message 27 of 27
AMAZING!
It works! Thank you W!
