Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Using iLogic to rename occurence - help
4 REPLIES 4
1030 Views, 4 Replies
Hi.
I am trying to create a code based on this (Provided in another thread by Curtis Waguespac)
oName = InputBox("Enter a Name", "iLogic", "FrameWork")
' set a reference to the assembly component definintion.
' This assumes an assembly document is open.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
i=0
'Iterate through all of the occurrences
Dim oOccurrence As ComponentOccurrence
For Each oOccurrence In oAsmCompDef.Occurrences
i=i+1
oOccurrence.Name = oName & ":" & i
Next
It works great, but I need it to change the name but not the occurrence number.
Kinda like this:
Names of part files:
One type name:1
One type name:2
One type name:3
One type name:4
Another type name:1
Another type name:2
Another type name:3
Yet another type name:1
Yet another type name:2
Yet another type name:3
to
Framework:1
Framework:2
Framework:3
Framework:4
Framework:1
Framework:2
Framework:3
Framework:1
Framework:2
Framework:3
I found some codes that can separate the name from the number, but can figure out how to make it work properly,
Any help would really be appreciated 🙂
4 REPLIES 4
bshbsh
that won't work, because you can not have identical occurrence names multiple times within one assembly.
in reply to: bshbsh
Ops, sorry.
I see I must have been a bit in a rush and a bit tired when writing the examples.
Let me show with real part name scenario
300_001:1
300_001:2
300_001:3
300_001:4
100_001:1
100_001:2
100_001:3
300_002:1
300_002:2
300_002:3
to
Framework_001:1
Framework_001:2
Framework_001:3
Framework_001:4
Framework_002:1
Framework_002:2
Framework_002:3
Framework_003:1
Framework_003:2
Framework_003:3
I ultimately would like to be able to rename what is in front of the underscore, and keep in.ex _001:1 & _001:2 etc.
I have seen some solutions on this forum but not quite what I have had in mind, this is the closest I have seen:
Renaming browser nodes
I believe the solution is mentioned in that thread (?), but I can't see anyone actually posting a full code, just parts of the code.
I am unfortunately not as advanced in iLogic coding that I have managed to edit the scripts to suit my needs...yet 🙂
Ultimately a script that could do something similar to this function, just with browser occurrences:
bshbsh
you could use the InStr() function in occurrence names (strings) to find if it contains any substring. You could also use the Replace() string function to replace any part of a string if it mathces a given pattern or substring you specify.
But in your case it seems like you always replace something in the beginning of the name, the part to the left of the first underscore, so I used the Left function instead.
	If InStr(oOccurrence.Name, "_") > 0 Then
		oOccurrence.Name = Replace(oOccurrence.Name, Left(oOccurrence.Name, InStr(oOccurrence.Name, "_")), "Framework_")
	End If
Next
hope that helps.
in reply to: bshbsh
Thank you, this was perfect 🙂
Technology Administrators
