I'm looking for some help figuring out how to create an iLogic rule that automatically renames the browser nodes based on part number. I know that this is a function in Inventor itself. The problem is that there is no built-in functionality to automatically change the default browser name to something besides part number. I've done a lot of digging and I came across the following code from an old thread discussing Inventor 2011. I am interested in 2013. It is also worth noting that when I run this code, my Inventor crashes.
If someone knows more about programming than I do and can get this to work, it would be much appreciated.
PrivateSubMain
UpdateAssyBrowser(ThisDoc.Document)
End Sub
PrivateSubUpdateAssyBrowser(ByValoDocAsInventor.Document)
DimoAssyAsInventor.AssemblyDocument
DimoCompAsInventor.ComponentOccurrence
DimoSubDocAsInventor.Document
DimNodeName()AsString
DimInstNumAsString
IfoDoc.DocumentType=Inventor.DocumentTypeEnum.kAssemblyDocumentObjectThen
oAssy=CType(oDoc, AssemblyDocument)
ForEachoCompInoAssy.ComponentDefinition.Occurrences
oSubDoc=CType(oComp.Definition.Document, Document)
NodeName=oComp.Name.Split(NewChar() {":"c}, StringSplitOptions.None)
InstNum=":"&NodeName(1)
oComp.Name=GetProp(oSubDoc, "Design Tracking Properties", "Part Number")&InstNum
IfoSubDoc.DocumentType=Inventor.DocumentTypeEnum.kAssemblyDocumentObjectThen
CallUpdateAssyBrowser(oSubDoc)
EndIf
NextoComp
EndIf
End Sub
PrivateFunctionGetProp(ByValoDocAsInventor.Document, ByValPropSetNameAsString, ByValPropNameAsString)AsString
DimoPropSetAsInventor.PropertySet
DimsHoldAsString=""
oPropSet=oDoc.PropertySets(PropSetName)
DimoPropAsInventor.Property
ForEachoPropInoPropSet
IfoProp.DisplayName="Part Number"Then
sHold=CStr(oProp.Value)
ExitFor
EndIf
NextoProp
ReturnsHold
End Function
Here you go. Please let me know if you have any questions on how this works:
Sub Main() 'Grab the Assembly Document
Dim oDoc As AssemblyDocument oDoc = ThisApplication.ActiveDocument 'Grab the Active Assembly Component Definition
Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition ' Get the model browser
Dim oPane As BrowserPane oPane = oDoc.BrowserPanes.Item("Model") ' Grab the occurrence of the object Dim oOcc As ComponentOccurrence For Each oOcc In oDoc.ComponentDefinition.Occurrences 'Grab Document from Occurrence
Dim oOccDoc As Document oOccDoc = oOcc.Definition.Document 'get design properties set'
Dim invDesignInfo As PropertySet invDesignInfo = oOccDoc.PropertySets.Item("Design Tracking Properties") ' Get the part number property.
Dim invPartNumberProperty As Inventor.Property invPartNumberProperty = invDesignInfo.Item("Part Number") ' Get the browser node that corresponds to the new item
Dim oSubAssyNode As BrowserNode oSubAssyNode = oPane.GetBrowserNodeFromObject(oOcc) If oSubAssyNode.NativeObject.Name <> invPartNumberProperty.Value Then 'Set The name
oSubAssyNode.NativeObject.Name = (invPartNumberProperty.Value) End If Next End Sub
That code looks like it works better, the only problem there is that it doesn't detect the instance number, so when I have
part001:1
part001:2
I get an error if I try to run the rule. I appreciate the help!
I would like to be able to maintain the instance number as is in Inventor so that the above example would be
partnumber001:1
partnumber001:2
That shouldn't be too hard. You just need to check if a name already exists and add :X to the end where X is the most recent instance +1. I'm out of time today but I might be able to whip that up in the next few days.
Alright I got it after playing with it a little bit. I added the appropriate code and it works perfectly. I really appreciate your help!
Dim NodeName() As String NodeName=oOcc.Name.Split( {":"c},StringSplitOptions.None) InstNum=":" & NodeName(1)
I have the code set to iterate through the active assembly and rename all non standard content Center components based on Description.
As a disclaimer, this code will not count unique occurrences for components.
Working perfect on my machine. I'm working with multi sheets.
oDoc = ThisDoc.Document
oSheets = oDoc.Sheets
For Each oSheet In oSheets
oSheet.activate
oView = oSheet.DrawingViews.Item(1)
modelName = oView.ReferencedDocumentDescriptor.ReferencedDocument
oProp = modelName.PropertySets.Item("Design Tracking Properties")
ActiveSheet.Sheet.Name = oProp.Item("Part Number").Value & " " & oProp.Item("Description").Value & " " & oProp.Item("Authority").Value
Next
oSheets(1).activate
Thank's a lot. I can see where I failed, but my skills was not good enough to figure it out myself. This works perfect. Thank you again.
Can someone please help,
I have modified this script to rename the nodes as "Part Number - Revision Number"
There is an assembly file in it I don't want it to change, could somone show me what to add and so it skips over this one?
The node name for this file is "02002.Tube and Pipe Runs"
Thanks in advance.
I have a quastion about this old post.
When i want to customize the rule with other properties.
It will fail and not work again.
original:
' Get the part number property. Dim invPartNumberProperty As Inventor.Property invPartNumberProperty = invDesignInfo.Item("Description")
The description i want to change to multiple properties like Partnumber, description, title.
I can't get it to work like that.
Any suggestions?
Further i noticed that this rule only work at the first level from the BOM structure.
The only childeren from assemblies doesn't update.
I don't know how we can edit this.
Thanks in advance!
I have found a Ilogic rule to do the trick.
This Ilogic rule i have modified with the needed properties.
When you want to use VBA you write a code that opens this Ilogic rule.
Sub Main Dim oADoc As AssemblyDocument = ThisApplication.ActiveDocument Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition Dim i As Integer = 0 For Each oOcc As ComponentOccurrence In oADef.Occurrences SetOccName(oOcc, i) i = i + 1 Next End Sub Sub SetOccName(oComp As ComponentOccurrence, oInt As Integer) Dim oOccDoc As Document = oComp.Definition.Document Dim oPSets As PropertySets = oOccDoc.PropertySets Dim oPNEmpty As Boolean = False Dim oArticleNoEmpty As Boolean = False Dim oTitleEmpty As Boolean = False Dim oPN As String = oPSets.Item(3).Item("Part Number").Value If String.IsNullOrEmpty(oPN) Then oPNEmpty = True Else oPNEmpty = False Dim oTitle As String = oPSets.Item(1).Item("Title").Value If String.IsNullOrEmpty(oTitle) Then oTitleEmpty = True Else oTitleEmpty = False Dim oArticleNo As String Try 'the custom iProperty may not exist, so use Try...Catch block to check it oArticleNo = oPSets.Item(4).Item("Article No").Value Catch 'above failed, so it was not found 'create it, or ignore it, or show a message End Try If String.IsNullOrEmpty(oArticleNo) Then oArticleNoEmpty = True Else oArticleNoEmpty = False Dim oNewName As String = "" 'to assemble name in variable first (no errors expected) 'could just set it up so that if any are missing or empty, skip trying to rename this component to simplify 'If oPNEmpty Or oArticleNoEmpty Or oTitleEmpty Then Continue For 'skip to next item in loop If oPNEmpty = False And oArticleNoEmpty = False And oTitleEmpty = False Then 'all present oNewName = oPN & " (" & oArticleNo & " " & oTitle & ")" & "-" & oInt ElseIf oPNEmpty = False And oArticleNoEmpty = True And oTitleEmpty = False Then 'ArticleNo missing oNewName = oPN & " (" & oTitle & ")" & "-" & oInt ElseIf oPNEmpty = True And oArticleNoEmpty = False And oTitleEmpty = False Then 'PN missing oNewName = "(" & oArticleNo & " " & oTitle & ")" & "-" & oInt ElseIf oPNEmpty = False And oArticleNoEmpty = False And oTitleEmpty = True Then 'Title missing oNewName = oPN & " (" & oArticleNo & ")" & "-" & oInt ElseIf oPNEmpty = True And oArticleNoEmpty = False And oTitleEmpty = True Then 'PN & Title missing oNewName = "(" & oArticleNo & ")" & "-" & oInt ElseIf oPNEmpty = False And oArticleNoEmpty = False And oTitleEmpty = True Then 'ArticleNo & Title missing oNewName = oPN & "-" & oInt End If Try 'just in case changing component name fails oComp.Name = oNewName Catch End Try 'reset all String variables to empty (very likely not necessary, but we'll see) oNewName = "" oPN = "" oArticleNo = "" oTitle = "" If oComp.SubOccurrences.Count > 0 Then 'if it has any SubOccurrences, it's a sub-assembly For Each oSOcc As ComponentOccurrence In oComp.SubOccurrences SetOccName(oSOcc, oInt) Next End If End Sub
Thank you! I have used the rule with great success, but recently got an error message:
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.ComponentOccurrence.get_Definition()
at ThisRule.SetOccName(ComponentOccurrence oComp, Int32 oInt)
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Any idea on what's wrong here?
(PS! No "expert" in iLogic and coding 😅)
at ThisRule.Main()
