I'm using Inventor and Vault 2023, and my workspace is based on my C: drive. The company I work for uses a network drive (common NAS device) as well to access engineering documents. Is there a way to set up iLogic triggers or rules where when I publish a PDF to my C: drive, it publishes to our M: drive (network drive from above) as well? Are there any tools in the Vault job processor that would aid in this? Should I just bite the bullet and take the few extra keystrokes to publish to multiple drives or copy/paste my drawings over instead of trying to automate this task? Any suggestions or alternatives would be appreciated! Thanks!
Solved by Michael.Navara. Go to Solution.
I like to use the api control definition commands instead of iLogic when exporting pdf's. Here is an example:
You can make it an event trigger 'After Save' and it works too.
Dim oName As String = ThisDrawing.Name & ".pdf" Dim oCmd As ControlDefinition oCmd = ThisApplication.CommandManager.ControlDefinitions.Item("AppFileExportPDFCmd") cfilelocation = "C:\temp\" mfilelocation = "M:\Folder1\" ThisApplication.CommandManager.PostPrivateEvent(PrivateEventTypeEnum.kFileNameEvent, cfilelocation & oName) oCmd.Execute
You can use any iLogic rule for export to PDF. Setup the output to your C:\ drive and later on copy the file to M:\
Something like this code snippet
Sub Main()
CADS_PubblishPDF()
End Sub
Sub CADS_PubblishPDF()
' Get the PDF translator Add-In.
Dim PDFAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
' a reference to the active document (the document to be published).
Dim oDocument As Document = ThisApplication.ActiveDocument
Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
oOptions.Value("Sheet_Range") = PrintRangeEnum.kPrintAllSheets
' Check whether the translator has 'SaveCopyAs' options
If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
' Options for drawings...
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
oOptions.Value("All_Color_AS_Black") = 0
'oOptions.Value("Remove_Line_Weights") = 0
'oOptions.Value("Vector_Resolution") = 400
'oOptions.Value("Custom_Begin_Sheet") = 2
'oOptions.Value("Custom_End_Sheet") = 4
End If
' the destination file name
Dim pdfFileNameLocal = ThisDoc.PathAndFileName(False) & ".pdf"
oDataMedium.FileName = pdfFileNameLocal
'Publish document.
Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'Copy file to Network drive
Dim pdfFileNameOnNetworkDrive = "M:\" & ThisDoc.FileName(False) & ".pdf"
System.IO.File.Copy(pdfFileNameLocal, pdfFileNameOnNetworkDrive)
End Sub
Thanks for the reply. I don't have the API tools installed on my machine currently- do you use developer or user tools to execute the code you're suggesting?
No, this is just iLogic rule. You don't need to install anything special
