Here you go:
option explicit on
'''Will set the appearance of a part file expect for those faces which have a name.
Public Sub Main()
If TypeOf ThisApplication.ActiveDocument Is PartDocument Then
ResetNamedFacesToDesiredAppearance(ThisApplication.ActiveDocument)
Else
MessageBox.Show("Only runs in part files!")
End If
End Sub
Public machinedFaceMaterialName As String = "Machined - Aluminum"
Public flangeFaceNamePrefix As String = "FlangeFace*"
''' <summary>
''' Resets named faces whose prefix matches that above to the desired material
''' </summary>
''' <param name="partDoc"></param>
Public Sub ResetNamedFacesToDesiredAppearance(ByVal partDoc As PartDocument)
'unecessary, but *should* IMHO work?
' Dim assetLib As AssetLibrary = ThisApplication.AssetLibraries.Item("Autodesk Appearance Library")
'language-agnostic:
' assetLib = ThisApplication.AssetLibraries.Item("AD121259-C03E-4A1D-92D8-59A22B4807AD")
Dim appearanceObjs As ObjectCollection = partDoc.AttributeManager.FindObjects("iLogicEntityNameSet", "iLogicEntityName", flangeFaceNamePrefix)
If appearanceObjs.Count > 0 Then
For Each obj As Object In appearanceObjs
If TypeOf obj Is SurfaceBody Then
ElseIf TypeOf obj Is PartFeature Then
ElseIf TypeOf obj Is Face Then
Dim thisFace As Face = obj
'this doesn't work but I'll leave it for others to comment upon!
' Dim faceAppearance As Asset = assetLib.AppearanceAssets(machinedFaceMaterialName)
' thisFace.Appearance = faceAppearance ' faceName
Dim oStyle As RenderStyle = partDoc.RenderStyles.Item(machinedFaceMaterialName)
Call thisFace.SetRenderStyle(kOverrideRenderStyle, oStyle)
End If
Next
End If
End Sub**If someone could tell me why the "face.appearance = faceAppearance" line doesn't work that would be great!
Otherwise, this needs to be in an iLogic rule that is tied to an event trigger for material change:
![2018-08-06 16_46_17-Autodesk Inventor Professional 2019 - [Flange Face Example.ipt].png 2018-08-06 16_46_17-Autodesk Inventor Professional 2019 - [Flange Face Example.ipt].png](https://forums.autodesk.com/t5/image/serverpage/image-id/531576i9E73110C02394973/image-size/large?v=v2&px=999)
I forgot to add that the attached file is 2019 format, but everyone is using that now right, right?
