How do I change color of an assembly change color to "RAL 7035" ?
I need to work on all Assembly
And to use Ilogic and I use before save
Solved by Sergio.D.Suárez. Go to Solution.
This rule changes the color of all occurrences of the assembly, select the default library color, do not put your color because my library does not have it, and to test the code I assembled it (I tried it and it worked for me)
Dim oAsset As Asset Dim oAsset_Array As New ArrayList For Each oAsset_Array_X In ThisApplication.ActiveAppearanceLibrary.AppearanceAssets oAsset_Array.Add(oAsset_Array_X.DisplayName) oAsset_Array.Sort() Next 'present the user with the list to choose from 100: oAsset_Array_Selected = InputListBox("CHOOSE TEXTURE FROM ABOVE LIST", oAsset_Array, oAsset_Array.Item(0), "TEXTURE SELECTION", "LIST OF TEXTURES") If oAsset_Array_Selected = "" Then GoTo 100 : '--------------------------------------------------------- Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisDoc.Document Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = oAsmDoc.ComponentDefinition Dim oOccurrence As ComponentOccurrence For Each oOccurrence In oAsmCompDef.Occurrences Component.Color(oOccurrence.name)=oAsset_Array_Selected iLogicVb.UpdateWhenDone = True Next
I guess you should have a line something like this
Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisDoc.Document Dim oAsmCompDef As AssemblyComponentDefinition oAsmCompDef = oAsmDoc.ComponentDefinition Dim oOccurrence As ComponentOccurrence For Each oOccurrence In oAsmCompDef.Occurrences Component.Color(oOccurrence.name)="RAL 7035" iLogicVb.UpdateWhenDone = True Next
I hope it helps to solve your problem, greetings
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thanks that was just what I needed to do the next step in the Ilogic code I am working on... Do you know way it come with I warring that it only works in Assambly ? I have found a workaround ... by simple make it a standalone code aand just make my other code run it when needed ... but I would love to be enable to use it at one code without the warring
please excuse me @Darkforce_the_ilogic_guy , but the language barrier does not allow me to understand exactly what you are looking for, if you explain in more detail I would like to help you in something.
Mechanical Designer
Hoping that below iLogic code helps to change asset only for assembly component in assembly.
Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument Dim oAsmDef As AssemblyComponentDefinition oAsmDef = oAsmDoc.ComponentDefinition 'check that the active document is an assembly file If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then MessageBox.Show("Please run this rule from the assembly file.", "iLogic") Exit Sub End If Dim localAsset As Asset = Nothing Try localAsset = oAsmDoc.Assets.Item("RAL 7035") Catch Dim assetLib As AssetLibrary = ThisApplication.AssetLibraries.Item("Autodesk Appearance Library") Dim libAsset As Asset = assetLib.AppearanceAssets.Item("RAL 7035") ' Copy the asset locally. localAsset = libAsset.CopyTo(oAsmDoc) End Try Dim oCompOcc As ComponentOccurrence For Each oCompOcc In oAsmDef.Occurrences If oCompOcc.ReferencedDocumentDescriptor.ReferencedDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then oCompOcc.Appearance = localAsset End If Next
Thanks and regards,
it is ok. the code you give me. did the part I needed help with.
I did only need help with part of my code. And your code did that i needed.
my complete code ... Ask the user to add a surface to custom Iperperties... IF the part or assambly is Raw, Colour 1, and so on.
with the new code i add ... it now change the colour of the part or Assambly to the Colour that it would have .. withour the user have to do it them self... and it change this in all view.
but most of the other just I already know how to do
