Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Use iLogic to check for user parameter, create it, populate it
4 REPLIES 4
1714 Views, 4 Replies
I am trying to get some simple iLogic code to run and I could use some (probably very basic) help.
Essentially, I need to complete my If/Then statement to do the functions in my comment quotes below.  I basically want to check for a parameter named 'PartNumber' in any existing document in which the user opens (and clicks 'Save' or updates iProperties).  If it exists, I want to assign it the 'MFPN' variable value (taken from the iProperties).  If it does not exist, I want to create it, then assign the 'MFPN' variable value to it.
Any help is appreciated greatly.  The simpler the solution the better, as I am very novice at understanding and/or maintaining programming code.
 Here's what I have...
iProperties.Value("Project", "Part Number") = ThisDoc.FileName(False) 'without extension
MFPN = iProperties.Value("Project", "Part Number")
If My_Expression Then
'If "PartNumber" parameter exists in this file, populate it with MFPN variable
Else
'If "PartNumber" parameter does not exist, create it, then populate it with MFPN variable
End If
iLogicVb.UpdateWhenDone = True
4 REPLIES 4
Owner2229
Hey, you can't use a name with space as parameter name, hence: "Part_Number":
Dim oDoc As Document = ThisApplication.ActiveDocument
Dim oParas As UserParameters = oDoc.ComponentDefinition.Parameters.UserParameters
Dim oPara As UserParameter
Try
    oPara = oParas.Item("Part_Number")
Catch
    oPara = oParas.AddByValue("Part_Number", "", UnitsTypeEnum.kTextUnits)
End Try
Dim MFPN As String = ThisDoc.FileName(False) 'without extension
iProperties.Value("Project", "Part Number") = MFPN
oPara.Value = MFPN
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
in reply to: Owner2229
Thank you @Owner2229. I dont have the issue of parameter regenerating. I modify your code to have an inputbox but it doesnt change the value.
A_BracketL = InputBox("Enter DRV_A_BracketL Value", "Left Bracket Angle", 91.23)
Try
    oPara = oParas.Item("DRV_A_BracketL")
Catch
    oPara = oParas.AddByValue("DRV_A_BracketL", A_BracketL, UnitsTypeEnum.kDegreeAngleUnits) 'DRV_A_BracketL/57.29577951
End Try
JelteDeJong
try it this way.
Dim A_BracketL = InputBox("Enter DRV_A_BracketL Value", "Left Bracket Angle [Deg]", 91.23)
Try
Catch
    oPara = oParas.AddByValue("DRV_A_BracketL", 0, UnitsTypeEnum.kDegreeAngleUnits)
End Try
' create a number from the text.
Dim doubleValue As Double = Double.Parse(A_BracketL)
'inventor expects radians. convert the deg to rad.
'inventor will convert it back to Deg when that value is shown to the user.
doubleValue = doubleValue*(Math.PI/180)
oPara.Value = doubleValue
Jelte de Jong
Blog: hjalte.nl - github.com
in reply to: JelteDeJong
Works perfectly @JelteDeJong . Thank you very much.
Technology Administrators
