Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Upload PDF file to Vault Basic with iLogic
2 REPLIES 2
youann21700
207 Views, 2 Replies
Morning/Afternoon
I have been desperately searching for a solution to this problem. Currently when we approve and issue a drawing with our revision control iLogic system, the drawing files is saved/checked in etc, and a PDF version of the drawing is created and saved to the C: drive. Ideally I want to upload this PDF to the Vault automatically as well, rather than hoping people remember to manually upload them.
I know this can be done with Vault Pro using:
oVltCon.FileManager.UploadFiles
, but I don't have that option. Any ideas?
2 REPLIES 2
youann21700
in reply to: youann21700
Anyone? at least tell me its not possible so I can sleep tonight.
youann21700
Solved it! The trick was to have the published PDF file as a referenced file on the drawing, so when the drawing file is checked in, the referenced PDF is also checked in.
My code is below for anyone else who has this issue. Ill do a brief summary of what it does.
1. Starts a transaction
2. Exports the PDF file with correct formatting etc. read-only
3. Attaches the PDF to the drawing file as a referenced document
the end
'CODE BY EUAN YOUR WELCOME
'THIS STARTS A TRANSACTION, WHATEVER THAT IS, THEY CAN TRACK CHANGES TO A DOCUMENT, THEREFORE CAN BE REVERSED
Sub Main()
	Dim trans As Transaction = ThisApplication.TransactionManager.StartTransaction(ThisApplication.ActiveDocument, "Export and Attach PDF file")
	Try
		If Not ThisApplication.ActiveDocument.FullFilename = String.Empty Then 'won't run if the active document isn't saved.
			Dim filenameToAttach As String = ExportToPDF()
			If Not filenameToAttach = String.Empty Then
				Dim doc As Document = ThisApplication.ActiveDocument
				AddReferences(doc, filenameToAttach)
		Else
			MessageBox.Show("File not saved; save the file and try again!")
			trans.Abort()
		trans.End()
	Catch
		trans.Abort()
	End Try
End Sub
'MAIN FUNCTION, EXPORTS A PDF FILE OF THE DRAWING, REMOVES LINE WEIGHTS, MAKES READ ONLY (ITS AN ISSUED DRAWING SO READ ONLY IS NEEDED)
Function ExportToPDF() As String
	Dim filename As String
	' Get the PDF translator Add-In, that is the long string, others for other file formats are online somewhere.
	Dim oPDFTranslator As TranslatorAddIn
	oPDFTranslator = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	Dim oContext As TranslationContext
	oContext = ThisApplication.TransientObjects.CreateTranslationContext
	Dim oOptions As NameValueMap
	oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	If oPDFTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
		oOptions.Value("Remove_Line_Weights") = 1
		oOptions.Value("Sheet_Range") = kPrintAllSheets
	    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	    Dim oData As DataMedium
	    oData = ThisApplication.TransientObjects.CreateDataMedium
		oData.FileName = ThisDoc.Path & "\Issued\" & ThisDoc.FileName(False) & " REV " & iProperties.Value("Project", "Revision Number") & " " & iProperties.Value("Custom", "ReleaseStatus") & " .pdf"
		checkpath = ThisDoc.Path & "\Issued"
		Dim oFolder As String = checkpath
		If Not System.IO.Directory.Exists(oFolder) Then
		System.IO.Directory.CreateDirectory(oFolder)
		oPDFTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData)
		filename = oData.FileName
		Dim oFile As System.IO.FileInfo
		oFile = New System.IO.FileInfo(filename)
		oFile.IsReadOnly = True
	If System.IO.File.Exists(filename) Then
		Return filename
	Else
		Return ""
End Function
'THIS PART MAKES THE PDF A REFERENCED DOCUMENT IN THE DRAWING, MEANS WILL BE CHECKED IN/OUT WITH THE DRAWING, this solves the issue of that initial check-in
Public Sub AddReferences(ByVal odoc As Inventor.Document, ByVal selectedfile As String)
	Dim oleReference As ReferencedOLEFileDescriptor
	If selectedfile.Contains("|") Then ' we have multiple files selected.
		Dim file As String() = selectedfile.Split("|")
		For Each s As String In file
			oleReference = odoc.ReferencedOLEFileDescriptors _
				.Add(s, OLEDocumentTypeEnum.kOLEDocumentLinkObject)
			oleReference.BrowserVisible = True
			oleReference.Visible = False
			oleReference.DisplayName = Mid$(s, InStrRev(s, "\") + 1)
		Next
	Else
				.Add(selectedfile,OLEDocumentTypeEnum.kOLEDocumentLinkObject)
		oleReference.DisplayName = Mid$(selectedfile, InStrRev(selectedfile, "\") + 1)
End Sub
Technology Administrators
