I'm trying to update mass/volume properties & remove any mass/volume overrides before running an export command with the settings I want.
The problem I'm running into is that I can't overwrite the iProperty dialog/value as seen in the picture below unless I do it manually. Even though the output of this code changes the Mass Override from True to False, the dialog still shows it as overwritten & the values still match the overwritten values.
' DEFINE DOCUMENT VARIABLES.
Public oDocument As Document = g_inventorApplication.ActiveDocument
Public oFileName As String = oDocument.DisplayName.Replace(".ipt", "")
Public oFilePath As String = oDocument.FullFileName.Replace("\" & oFileName & ".ipt", "")
' DEFINE PART DOCUMENT VARIABLES.
Public oPartDocument As PartDocument = g_inventorApplication.ActiveDocument
Public oPartCompDef As PartComponentDefinition = oPartDocument.ComponentDefinition
Public oMassProps As MassProperties = oPartCompDef.MassProperties
Public oMass As Double = oMassProps.Mass
Public oMassOverW As Boolean = oMassProps.MassOverridden
Public oVolume As Double = oPartCompDef.MassProperties.Volume
Public oVolumeOverW As Boolean = oMassProps.VolumeOverridden
' DEFINE COMMAND MANAGER VARIABLES.
Public oCommandManager As CommandManager = g_inventorApplication.CommandManager
Public oControlDefs As ControlDefinitions = oCommandManager.ControlDefinitions
Public oControlDef As ControlDefinition
' DEFINE PROPERTY VARIABLS.
Public oPropSets As PropertySets = oPartDocument.PropertySets
Public oProjectPropertySet As PropertySet = oPartDocument.PropertySets.Item("Design Tracking Properties") 'PROPERTIESFORDESIGNTRACKINGPROPERTIESENUM
Public oMassProperty As Inventor.Property = oProjectPropertySet.Item("Mass")
Public oMassValue As Double = oMassProperty.Value
' DEFINE UNITS OF MEASURE VARIABLES.
Public oUnitOfMeas_g As Object = oPartDocument.UnitsOfMeasure.MassUnits
Public oUnitOfMeas_kg As Object = oPartDocument.UnitsOfMeasure.MassUnits
Public oUnitOfMeas_lb As Object = oPartDocument.UnitsOfMeasure.MassUnits
Public Sub Export_To_STL()
Debug.Print("Before Test") 'MsgBox("Before Test")
UpdateMassProps()
End Sub
Private Sub UpdateMassProps()
oUnitOfMeas_g = kGramMassUnits 'UNITSTYPEENUM
oUnitOfMeas_kg = kKilogramMassUnits 'UNITSTYPEENUM
oUnitOfMeas_lb = kLbMassMassUnits 'UNITSTYPEENUM
If oMassProps.AvailableAccuracy <> k_High Then 'Or k_VeryHigh Then
oMassProps.Accuracy = k_High
' RESULTS ARE NOT SAVED WITH THE DOCUMENT & DOCUMENT IS NOT 'DIRTIED'.
oMassProps.CacheResultsOnCompute = False
End If
oMass = Convert_Units(oMass, oUnitOfMeas_kg, oUnitOfMeas_lb)
oMassValue = Convert_Units(oMassValue, oUnitOfMeas_g, oUnitOfMeas_lb)
Debug.Print("oMassOverW Before: " & oMassOverW) 'MsgBox("oMassOverW Before: " & oMassOverW)
Debug.Print("oMassProp Dirty Before: " & oMassProperty.Dirty) 'MsgBox("oMassProp Dirty Before: " & oMassProperty.Dirty)
Debug.Print("oMass Before: " & oMass) 'MsgBox("oMass Before: " & oMass)
Debug.Print("oMassValue Before: " & oMassValue) 'MsgBox("oMassValue Before: " & oMassValue)
If oMassOverW = True Then
oMassOverW = False
End If
oControlDefs.Item("AppUpdateMassPropertiesCmd").Execute() 'Execute2(True)
oPartDocument.Update() 'Update2(True)
oPartDocument.Save()
Debug.Print("oMassOverW After: " & oMassOverW) 'MsgBox("oMassOverW After: " & oMassOverW)
Debug.Print("oMassProp Dirty After: " & oMassProperty.Dirty) 'MsgBox("oMassProp Dirty After: " & oMassProperty.Dirty)
Debug.Print("oMass After: " & oMass) 'MsgBox("oMass After: " & oMass)
Debug.Print("oMassValue After: " & oMassValue) 'MsgBox("oMassValue After: " & oMassValue)
End Sub
' CONVERT UNITS OF MEASUREMENT.
Private Function Convert_Units(oInputValue As Double, oInputUnits As Object, oOutputUnits As Object) As String
Dim oPartDocument As PartDocument
oPartDocument = g_inventorApplication.ActiveDocument
Convert_Units = oPartDocument.UnitsOfMeasure.ConvertUnits(oInputValue, oInputUnits, oOutputUnits).ToString
End Function
I've referenced a number of other forum posts talking about this but it doesn't seem to fix the problem I'm running into.
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/calculate-mass/m-p/10047266
Thanks for the help in advance!
Tyler
Solved by tyler.warner. Go to Solution.
Solved by llorden4. Go to Solution.
If you have all your other settings (u/m, etc) set as desired, then just send the desired override value to "iProperties.Mass". Send a value of -1 to restore to an Inventor controlled dynamic value. Example:
iProperties.Mass = MyValue 'your override value
iProperties.Mass = -1 'restore Inventor calculated value
Your second link shows pretty much the same thing, just tested this and it works for me. Perhaps it's a version issue. I'm working 2022.3 at present.
Isn't "iProperties.Mass" only in iLogic? I want to do this using the API in an Add-In.
I tried changing the mass value for both types of property to -1 (as seen below), the debug output value changes to -1 for both.
oMass = -1
oMassValue = -1
oMassOverW = False
End If
But...
-it doesn't reset the output value to the calculated mass
-the iProperty Window --> Physical Tab still shows the overwrite values.
Am I missing something?
This may not be anything, but sounds appropriate to point out...
The MassProperties object has a Property called 'CacheResultsOnCompute' that may need to be intentionally set in a situation like this. Just a thought.
Edit: Oops, didn't look close enough...I see you already have that in there.
Wesley Crihfield
(Not an Autodesk Employee)
I don't dabble in VB.net, but I can use iLogic to call the API and simply setting the the MassOverridden to False set it back to dynamically managed for me, didn't have to send the -1 value.
iLogic API call:
ThisDoc.Document.ComponentDefinition.MassProperties.MassOverridden = False
For your code, try...
If oMassOverW = True Then oMassOverW = False
Maybe a document update immediately thereafter?
Figured it out after looking at your comments & the links I posted a few more times. The part where I was messing up was changing the variable "oMassOverW" to "False" but not the actual property of the document as seen in the snippet below.
'oMassOverW = False ' INCORRECT
oMassProps.MassOverridden = False ' CORRECT
oMass = oMassProps.Mass
End If
If oVolumeOverW = True Then
'oVolumeOverW = False ' INCORRECT
oMassProps.VolumeOverridden = False
oVolume = oMassProps.Volume
End If
The entire corrected command has been posted below for future reference.
Public Sub UpdateMassProps()
' CHECK THAT PART FILE IS OPEN.
If oDocument.DocumentType <> kPartDocumentObject Then 'DOCUMENTTYPEENUM
MsgBox("The open file is not a part file. The command has been canceled.")
Exit Sub
End If
If oMassProps.Accuracy <> k_High Or k_VeryHigh Then
End If
End If
End If
oMass = Math.Round(oMass, 3, MidpointRounding.ToEven) 'SET PRECISION TO 3 DECIMAL PLACES
oVolume *= (0.3937008 ^ 3) 'CONVERT RESULT FROM CM^3 TO IN^3 'NOT AVAILABLE UNITSTYPEENUM
oVolume = Math.Round(oVolume, 3, MidpointRounding.ToEven) 'SET PRECISION TO 3 DECIMAL PLACES
End Sub
Dim oPartDocument As PartDocument = g_inventorApplication.ActiveDocument
End Function
