Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
update drawings before checking them into Vault
3 REPLIES 3
johan.degreef
326 Views, 3 Replies
johan.degreef
I need to add a style to all my old drawings, in order to make the Vault revision table work on them. Would it be possible to get help here, to have a rule to do that for me? I will run the rule drawing per drawing.
Add PTN_Revision
Set Revision Table/Tag to PTN_Revision
Many Thanks, Johan
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
Add PTN_Revision
Many Thanks, Johan
3 REPLIES 3
johan.degreef
Add PTN_Revision
I do have a ptn_revision.xml to import the style.
Add PTN_Revision
JelteDeJong
in reply to: johan.degreef
JelteDeJong
i assume that you have added your drawing syles to the global styles. In that case you could try this.
Dim doc As DrawingDocument = ThisDoc.Document
Dim revStyle
Try
	revStyle = doc.StylesManager.RevisionTableStyles.Item("PTN Revision")
Catch
	MsgBox("Could not get style with name: PTN Revision")
	return
End Try
If (revStyle.StyleLocation = StyleLocationEnum.kBothStyleLocation) Then
    revStyle.UpdateFromGlobal()
ElseIf (revStyle.StyleLocation = StyleLocationEnum.kLibraryStyleLocation) Then
    revStyle.ConvertToLocal()
For Each sheet As Sheet In doc.Sheets
    For Each table As RevisionTable In Sheet.RevisionTables
        table.Style = revStyle
    Next
Next
Jelte de Jong
Blog: hjalte.nl - github.com
Dim revStyle
Try
Catch
	return
End Try
    Next
Next
Jelte de Jong
Tony_Yates
Tony_Yates
Try this,
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
oSheet = oDrawingDoc.ActiveSheet
'-----------------------------------Add Revision table--------------------------------------
Dim oTablePt As Point2d
oTablePt = ThisApplication.TransientGeometry.CreatePoint2d(53.3, 57.8)
If oSheet.RevisionTables.Count = 0 Then
Dim oRevTableStyle As RevisionTableStyle
oRevTableStyle = oDrawingDoc.StylesManager.RevisionTableStyles.Item("Revision Table (PTN Revision)")
Dim oRevTable As RevisionTable
oRevTable = oSheet.RevisionTables.Add2(oTablePt, True, True, True, "A", oRevTableStyle, )
Else
MessageBox.Show("Revision Table already exist", "Autodesk Inventor")
Dim oRevTableItem As RevisionTable
oRevTableItem = oSheet.RevisionTables.Item(1)
Dim oWidthRevTable As Double
oWidthRevTable = oRevTableItem.RangeBox.MaxPoint.X - oRevTableItem.RangeBox.MinPoint.X
Dim oHeightRevTable As Double
oHeightRevTable = oRevTableItem.RangeBox.MaxPoint.Y - oRevTableItem.RangeBox.MinPoint.Y
Try this,
Dim oSheet As Sheet
Else
