Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Unexpected coincident constraints in projected sketchlines
2 REPLIES 2
273 Views, 2 Replies
I have discovered the situation when the projection of the horizontal line can be slanted without error indication. It seems like projecting procedure can introduce additional unwanted and unexpected constraints.
See details in attachment.
Any help with API detection and workaround will be appreciated.
ALink
ALink
2 REPLIES 2
There's definitely an issue with the way collinear
entities without a common endpoint are projected. It seems like the overlapping
end points should have come through in the projection instead of being merged
into one. Thanks for reporting this. I've logged this in our database (ID:
1146666).
I haven't thought about it too much, but I don't
think it'll be easy to come up with a generalized test to detect this problem.
You could either use the workaround you've found (of projecting before adding
the collinear constraint) or if the entities have already been projected, you
can project them again & compare points on the previously and newly
projected entities to make sure they are the same. If they are the same, you can
discard the newly projected entities.
Sanjay-
1146666).
Sanjay-
Sanjay, thank you.
Sanjay, thank you.
