Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
turn of underlayer in factory with ilogic
7 REPLIES 7
Message 1 of 8
Darkforce_the_ilogic_guy
543 Views, 7 Replies
Dim doc = ThisDoc.Document
	Dim sDocumentSubType As String = doc.SubType
	If sDocumentSubType = "{E60F81E1-49B3-11D0-93C3-7E0706000000}"
	If Component.Visible(iProperties.Value("Project", "Part Number")&".dwg") =True Then
	Component.Visible(iProperties.Value("Project", "Part Number")&".dwg") = False
Else
	Component.Visible(iProperties.Value("Project", "Part Number")&".dwg") = True
	End If
Else
End If
I want to make an code that turn the visbility on of off  in an factory layout. Can anyone tell me what I need to change in my code? it have to work on all my IAM factory files.  it is always call the same as the partnumber and  ".dwg" in the browser tree. but the normale componemt code does not seens to work . It keep saying it can´t find it
Tags (1)
7 REPLIES 7
Message 2 of 8
I know that normally, in an assembly, the component names usually get something like ":1" automatically added to the ends of their names, by default.  This can be a real pain when trying to specify Components by their Componene.Name.
I usually just loop through my components and check if oComp.Name.Contains("Name") = True, then process them.
I don't know if it would make much difference, but you could also try going one step deeper like this.
Component.InventorComponent("Part1").Visible =
 Do you know if it is finding the component or not?
Another thing I do to avoid that long unreadable string for document subtype is access the documents iProperty for SubTypeName, like this.
MsgBox("The SubType of the Active Document = " & oDoc.PropertySets.Item("Design Tracking Properties").Item("Document SubType Name").Value)
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 8
my problem is not there name... but that it seens that an Autocad link files does not count as an normale componemt.
there are not been add an :1 on this ... it is always call partnumber & ".dwg".  but no matter if i type the number .. if saying it can´t find it
Tags (1)
Message 4 of 8
Hi @Darkforce_the_ilogic_guy
The dwg is an imported component.
Try this iLogic code 🙂
Dim oDoc As Document = ThisDoc.Document
Dim sDocumentSubType As String = oDoc.SubType
	Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
	Dim orefComp As ImportedComponent
	Dim orefCompName As String = iProperties.Value("Project", "Part Number") & ".dwg"
	orefComp = oDef.ImportedComponents.Item(orefCompName)
	If orefComp.Visible
		orefComp.Visible = False
	Else
		orefComp.Visible = True
	End If
End If
Message 5 of 8
JhoelForshav
in reply to: JhoelForshav
On a side note; If the dwg is imported in a part document you'll find it under ComponentDefinition.ReferenceComponents.ImportedComponents. So in order to make the rule work in both part and assembly documents it'll have to look something like this:
If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject
	Try
	Catch
		MessageBox.Show("No imported component with name: " & orefCompName & " exists in the document", _
		"Cannot find component", MessageBoxButtons.OK, MessageBoxIcon.Information)
		Exit Sub
	End Try
ElseIf oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject
	Dim oDef As PartComponentDefinition = oDoc.ComponentDefinition
	Try
		orefComp = oDef.ReferenceComponents.ImportedComponents.Item(orefCompName)
	Catch
		Exit Sub
	End Try
End If
If orefComp.Visible
Else
End If
Message 6 of 8
The DWG is an drawing generator by inventor form the Assets in 3d to an dwg by synz the Inventor iam to Autocad. I do not know how the program add it to Iam. Only that it always are call the same as the part number of the iam and add an extension. As an autocad file (.DWG). but the code to make an standard component change visibility does not seems to work
Message 7 of 8
I see... I don't have the factory design utilities myself, but I'm thinking it might be a ReferencedOLEFileDescriptor....
Try this rule and se if it gives you any messagebox:
Dim oDoc As AssemblyDocument = ThisDoc.Document
Dim oleReference As ReferencedOLEFileDescriptor
For Each oleReference In oDoc.ReferencedOLEFileDescriptors
	MsgBox(oleReference.DisplayName)
Next
Message 8 of 8
as it turn out that code did work . Thanks  for the help. I add an marco that run that code. and made a buttom.  so now I can do somthing in sekund that easy take minutes. the file that I test it on I did not even manage do it at all .. My computer frezz up it I try to use the normale inventor function with the mouse. but it toke less the 3 secund when I use  our code/buttom
VBA code I use
Public Sub VisibleUnderlayer()
    Dim addIn As ApplicationAddIn
    Dim addIns As ApplicationAddIns
    Set addIns = ThisApplication.ApplicationAddIns
        For Each addIn In addIns
            If InStr(addIn.DisplayName, "iLogic") > 0 Then
                            addIn.Activate
                Dim iLogicAuto As Object
                Set iLogicAuto = addIn.Automation
                Exit For
            End If
        Next
    Debug.Print addIn.DisplayName
    Dim RuleName1 As String
    EXTERNALrule = "ChangeVisilibilityFactoryUnderlayer"
    'Dim RuleName2 As String
    'INTERNALrule = "Rule2"
      Set oDoc = ThisApplication.ActiveDocument
      If oDoc Is Nothing Then
        MsgBox "Missing Inventor Document"
        Exit Sub
      End If
    'iLogicAuto.RunRule oDoc, INTERNALrule 'for internal rule
    iLogicAuto.RunExternalRule oDoc, EXTERNALrule 'for external rule
End Sub
Tags (3)
