Message 1 of 10
Trying to add text to an idw, unable to cast COM object of type System._ComObject
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hey all,
I'm trying to add a text box to an idw file, but I'm getting the following error.
The weird part is that the code will open the file, and add the text box with the correct input, but THEN throws this error? It is happening within another subroutine that is mass-exporting PDFs from all passed idw files within the assembly that runs the rule.
Sub MakePDFFromDoc(oDocument As String, UserSelectedAction As Integer, folderName As String, jobNum As String, Qty As String) oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") ' oMsg = MessageBox.Show(oDocument, "FolderName") oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap oDataMedium = ThisApplication.TransientObjects.CreateDataMedium oFile = ThisApplication.Documents.Open(oDocument, True) 'Create Job Number/Qty Text Box on the idw Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument Dim oSketch As DrawingSketch = oDrawDoc.ActiveSheet.Sketches.Add oSketch.Edit Dim oTG As TransientGeometry = ThisApplication.TransientGeometry Dim JBText As String = "<" & jobNum & ">" Dim oTextBox As System.Windows.Forms.TextBox oTextBox = oSketch.TextBoxes.AddFitted(oTG.CreatePoint2d(2, 2), JBText) oSketch.ExitEdit oFullFileName = oFile.File.FullFileName ' oMsg = MessageBox.Show(folderName, "oFullFileName") oPath = Left(oFullFileName, InStrRev(oFullFileName, "\") -1) ' oMsg = MessageBox.Show(folderName, "oPath") oFileName = Right(oFullFileName, Len(oFullFileName) -InStrRev(oFullFileName, "\")) ' oMsg = MessageBox.Show(folderName, "oFileName") oFilePart = Left(oFileName, InStrRev(oFileName, ".") -1) ' oMsg = MessageBox.Show(folderName, "oFilePart") oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 0 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'get PDF target folder path oFolder = folderName ' oMsg = MessageBox.Show(oFolder, "oFolder") oDirectoryName = System.IO.Path.GetDirectoryName(oFullFileName) ' oMsg = MessageBox.Show(oDirectoryName & oFolder, "oDirectoryName") 'Check for the PDF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If 'Set the PDF target file name oDataMedium.FileName = oFolder & "\" & oFilePart & ".pdf" 'Publish document If (UserSelectedAction = 1) Or (UserSelectedAction = 3) Then oPDFAddIn.SaveCopyAs(oFile, oContext, oOptions, oDataMedium)'For PDF's End If If (UserSelectedAction = 2) Or (UserSelectedAction = 3) Then oFile.SaveAs(oFolder & "\" & oFilePart & ".dwg", True) 'For DWG's End If oFile.Close '------end of iLogic------- End Sub
The idw file's full address is passed in. oFile was originally running as an invisible open, but I had to change it as it was trying to add the textbox to the assembly file haha.
