Triggering a rule run on a part when its placed into a assembly
1 REPLY 1
NikelARH4K2
160 Views, 1 Reply
NikelARH4K2
This code will be placed on part itself and i want it run when someone places it in a assembly. I cant use the save trigger because of restrictions
customPropertySet = ThisDoc.Document.PropertySets.Item("Inventor User Defined Properties")
Dim iprop(1) As String
iprop(1) = "Sync_Data"
Try
      prop = customPropertySet.Item(iprop(1))
Catch
      customPropertySet.Add("", iprop(1))
End Try
Dim partNumber As String = iProperties.Value("Project", "Part Number")
partNumber = partNumber.Trim().ToUpper()
i = GoExcel.FindRow("P:\_MASTER_PART_LIST\MASTER_PART_LIST.xls", "MASTER_PART_LIST", "Part No.", "=", partNumber)
If Not iProperties.Value("Project", "Description") = GoExcel.CurrentRowValue("Description") And iProperties.Value("Custom", "Sync_Data") = "False"
	GoTo Send_Email
Else If Not iProperties.Value("Project", "Description") = GoExcel.CurrentRowValue("Description") And iProperties.Value("Custom", "Sync_Data") = "True"
	GoTo Update_Info
End If
Update_Info:
If i = -1
	iProperties.Value("Project", "Description") = "The entered Part Number does not exist in the Master Parts List"
	iProperties.Value("Project", "Vendor") = "The entered Part Number does not exist in the Master Parts List"
	GoTo Skip_Email
Else
	iProperties.Value("Project", "Vendor") = GoExcel.CurrentRowValue("Manufacturer")
	Dim partDescription As String = iProperties.Value("Project", "Description")
	partDescription = partDescription.ToUpper()
	iProperties.Value("Project", "Description") = partDescription
	iProperties.Value("Project", "Stock Number") = "MFG Part #" & iProperties.Value("Project", "Part Number")
	Dim partVendor As String = iProperties.Value("Project", "Vendor")
	partVendor = partVendor.ToUpper()
	iProperties.Value("Project", "Vendor") = partVendor
	GoTo Skip_Email
End If
Send_Email:
	oOApp = CreateObject("Outlook.Application")
oOMail = oOApp.CreateItem(0)
strbody = "The part number " & iProperties.Value("Project", "Part Number") & " iproperties does not match with the Master Parts List and requires update"
With oOMail
    .bodyformat=2
    .To = "Removed for Forums Post" ' The automatic send only works if a mailadress is set here
    .CC = ""
    .BCC = ""
    .Subject = iProperties.Value("Project", "Part Number") & " Iproperties is not current with Master Parts List"
    ''''' part that is missing
    . Display
    End With
    With oOMail
    .HTMLbody = strbody & vbNewLine & .HTMLBody ' add the signature without losing the HTML-formatting of the signature
    '.Attachments.Add ("C:\Test.jpg")
    '.Display 'To pop up the Mail just remove'
    .Send 'If you don't want to send automatic set '
    End With
	Skip_Email:
Try
Catch
End Try
	GoTo Send_Email
	GoTo Update_Info
End If
Update_Info:
If i = -1
	GoTo Skip_Email
Else
	GoTo Skip_Email
End If
Send_Email:
With oOMail
    .bodyformat=2
    .CC = ""
    .BCC = ""
    . Display
    End With
    With oOMail
    End With
	Skip_Email:
1 REPLY 1
Michael.Navara
I don't understand what is the reason.
If you have the library under your control, you can iterate all files in the library and check the values in single loop. You can repeat this check periodically when the XLS file is changed.
But to your question. If you want to check the files before use, you need to implement your own event handler for it. Default iLogic event handlers doesn't work properly for this purpose. The best approach is to implement your own add-in and call iLogic rule from this event handler. Or implement full code to this add-in.
If you want to choose the best event, you can use EventWatcher application from Inventor SDK. My recommended event is ApplicationEvents.OnOpenDocument Event.
