Total number of piercings in a sheet metal part
Message 1 of 8
I have been trying to create a macro that would add a custom property to my sheet metal parts that would tell me the total number of piercings in the part (holes and punches). So far I have the punches to count correctly but I am having issues with the holes, as I am getting an error. Any ideas?
Sub Piercings()
  'Get the part doc and sheet metal component defn.  No error handling:
  Dim oPartDocument As Inventor.PartDocument
  Set oPartDocument = ThisApplication.ActiveDocument
  Dim oSheetMetalComp As Inventor.SheetMetalComponentDefinition
  Set oSheetMetalComp = oPartDocument.ComponentDefinition
  'Dim oHoles As Inventor.HoleTables
  'Set oHoles = oPartDocument.ComponentDefinition
  'Get the pierce count
  Dim iHoleCount As Integer
  'iHoleCount = oHoles.Count
  Dim iPunchCount As Integer
  iPunchCount = oSheetMetalComp.FlatPattern.FlatPunchResults.Count
  Dim iPierceCount As Integer
  iPierceCount = iHoleCount + iPunchCount
  'Get the custom property set
  Dim oCustomProps As Inventor.PropertySet
  Set oCustomProps = oPartDocument.PropertySets.Item("Inventor User Defined Properties")
  'Define the name of the PIERCING count iproperty name:
  Dim sPiercePropName As String
  sPiercePropName = "PIERCINGS"
  'See if we already have an iproperty for the PIERCING count
  Dim oPierceProp As Inventor.Property
  Dim oProp As Inventor.Property
  For Each oProp In oCustomProps
    If oProp.Name = sPiercePropName Then
      'We already have an iproperty, we just need to write the new value
      Set oPierceProp = oProp
      oPierceProp.Value = iPierceCount
      Exit Sub
  Next oProp
  'We don't have an iproperty, so we create it and set its value
  If oPierceProp Is Nothing Then Set oPierceProp = oCustomProps.Add(iPierceCount, sPiercePropName)
End Sub
Replies (7)
Message 2 of 8
brendan.henderson
I have a macro that counts the pierces (for laser/plasma cutter). It counts all internal holes/shapes and then adds 1 for the uter shape. Let me know if this is of any interest to you.
Brendan Henderson
CAD Manager
New Blog | Old Blog | Google+ | Twitter
Inventor 2016 PDSU Build 236, Release 2016.2.2, Vault Professional 2016 Update 1, Win 7 64 bit
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 3 of 8
That would be great. That sounds like it will do what I am looking for.
Thank you,
Kyle
Message 4 of 8
jletcher
Message 5 of 8
I am looking to count the total number of holes not just the hole features in the part.
Thank you.
Message 6 of 8
jletcher
I understand... you will have to add the code for cut command and other command features you used.
Just thught it would help..
Message 7 of 8
brendan.henderson
Here is the VBA code I use. It creates 4 custm iProperties being OuterPerimeter, InnerPerimeters, TotalPerimeter and Pierces. I didn't write it (I think the author may have passed on) but I use it 100 times a day and it just works. Edit to suit your needs.
Sub GetIntExtPerimeters()
    Dim oPartDoc As Document
    Set oPartDoc = ThisApplication.ActiveDocument
    Dim oFlatPattern As FlatPattern
    ' Check for a non-part document
    If oPartDoc.DocumentType <> kPartDocumentObject Then
        MsgBox "The Active document must be a 'Part'!"
        Exit Sub
    ' The Active document must be a Sheet metal Part
    If oPartDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
        MsgBox "The 'Part' must be a Sheet Metal Part!"
        Exit Sub
    ' Check to see if the flat pattern exists.
    Set oFlatPattern = oPartDoc.ComponentDefinition.FlatPattern
    If oFlatPattern Is Nothing Then
        MsgBox "No flat pattern exists for this part!"
        Exit Sub
    Dim oSheetMetalCompDef As SheetMetalComponentDefinition
    Set oSheetMetalCompDef = oPartDoc.ComponentDefinition
    ' Get the cut length
    Dim oFace As Face
    Set oFace = oSheetMetalCompDef.FlatPattern.TopFace
    ' Find the outer loop.
    Dim dOuterLength As Double
    dOuterLength = 0
    Dim oLoop As EdgeLoop
    For Each oLoop In oFace.EdgeLoops
        If oLoop.IsOuterEdgeLoop Then
            Dim oEdge As Edge
            For Each oEdge In oLoop.Edges
                ' Get the length of the current edge.
                Dim dMin As Double, dMax As Double
                Call oEdge.Evaluator.GetParamExtents(dMin, dMax)
                Dim dLength As Double
                Call oEdge.Evaluator.GetLengthAtParam(dMin, dMax, dLength)
                dOuterLength = dOuterLength + dLength
            Next
            'MsgBox "Outer Loop is " & FormatNumber(dOuterLength, 1)
            Exit For
    Next
    ' Iterate through the inner loops.
    Dim iLoopCount As Long
    iLoopCount = 0
    Dim dTotalLength As Double
        Dim dLoopLength As Double
        dLoopLength = 0
        If Not oLoop.IsOuterEdgeLoop Then
                dLoopLength = dLoopLength + dLength
            Next
            ' Add this loop to the total length.
            dTotalLength = dTotalLength + dLoopLength
            'MsgBox "Inner Loops are " & FormatNumber(dTotalLength, 1)
    Next
'added by BH 13-07-2011-count edges to calculate peirces
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oDef As SheetMetalComponentDefinition
Set oDef = oDoc.ComponentDefinition
Set oFlatPattern = oDef.FlatPattern
Dim oTransaction As Transaction
Set oTransaction = ThisApplication.TransactionManager.StartTransaction(oDoc, "FindArea ")
Dim oSketch As PlanarSketch
Set oSketch = oFlatPattern.Sketches.Add(oFlatPattern.TopFace)
Dim oEdgeLoop As EdgeLoop
numLoops = 1
For Each oEdgeLoop In oFlatPattern.TopFace.EdgeLoops
    If oEdgeLoop.IsOuterEdgeLoop = False Then
        numLoops = numLoops + 1
Next
TotalPierces = numLoops
    If oEdgeLoop.IsOuterEdgeLoop Then
        Exit For
Next
For Each oEdge In oEdgeLoop.Edges
    Call oSketch.AddByProjectingEntity(oEdge)
Next
Dim oProfile As Profile
Set oProfile = oSketch.Profiles.AddForSolid
oTransaction.Abort
'end
    Dim oUOM As UnitsOfMeasure
    Set oUOM = oPartDoc.UnitsOfMeasure
    outerCutlength = oUOM.GetStringFromValue(dOuterLength, kMillimeterLengthUnits)
    innerCutlength = oUOM.GetStringFromValue(dTotalLength, kMillimeterLengthUnits)
    TotalCutLength = oUOM.GetStringFromValue(dTotalLength + dOuterLength, kMillimeterLengthUnits)
    'Write data to properties, creating or updating (if property exists)
    Dim oCustomPropSet As PropertySet
    Set oCustomPropSet = oPartDoc.PropertySets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
    On Error Resume Next
    oCustomPropSet.Item("OuterPerimeter").Value = outerCutlength
    If Err Then
        Err.Clear
        Call oCustomPropSet.Add(outerCutlength, "OuterPerimeter")
    oCustomPropSet.Item("InnerPerimeters").Value = innerCutlength
    If Err Then
        Err.Clear
        Call oCustomPropSet.Add(innerCutlength, "InnerPerimeters")
    oCustomPropSet.Item("TotalPerimeter").Value = TotalCutLength
    If Err Then
        Err.Clear
        Call oCustomPropSet.Add(TotalCutLength, "TotalPerimeter")
    oCustomPropSet.Item("Pierces").Value = TotalPierces
    If Err Then
        Err.Clear
        Call oCustomPropSet.Add(TotalPierces, "Pierces")
    End
End Sub
Brendan Henderson
CAD Manager
Message 8 of 8
Thanks!
I got that to work.
I simplified it to do just what I want it to do.
Sub Piercings()
  Dim oPartDoc As Inventor.PartDocument
  Set oSheetMetalComp = oPartDoc.ComponentDefinition
  Set oFlatPattern = oSheetMetalComp.FlatPattern
  Dim numLoops As Integer
  numLoops = 0
  Next
  Dim TotalPierces As Integer
  Set oCustomProps = oPartDoc.PropertySets.Item("Inventor User Defined Properties")
      oPierceProp.Value = TotalPierces
      Exit Sub
  Next oProp
  If oPierceProp Is Nothing Then Set oPierceProp = oCustomProps.Add(TotalPierces, sPiercePropName)
End Sub
