Evening all
Is there a way to change the text size and make it bold in a message box?
Inventor 2022
Donald
as far as i know it's not possible to change the text in a standard messagebox. But you can create a custom form with a RichTextBox .
Hi @donaldleigh. FYI: Back in 2019 I actually created an idea post on the Inventor Ideas Forum about this. If I knew then what I know now, I would not have created that post. At that time I was not familiar enough with the VB.NET programming language or Windows Forms to realize that Autodesk really did not have much control over that dialog, other than providing easy means by which to generate the code needed to use them for your iLogic rules. If you visit that post (link above) you will see that I revisited that post a couple years later with a followup message, which includes several links in it, to the source online documentation for that dialog and how it ties in with VB.NET and Microsoft, not Autodesk or Inventor or iLogic.
Wesley Crihfield
(Not an Autodesk Employee)
