Hello together,
I want check two objects for a collision in assembly. Therefore I developed an Addin with the Inventor API to use the "Interference Analysis" for those objects in an AssemblyDocument.
If there is an interference as a result of my check, I want to substract the "Interference Body" of the first object in its PartDocument.
Is there a way to use the SurfaceBody "InterferenceResult.InterferenceBody" to substract it from the first object in its PartDocument?
There is a screenshot inserted below to visualise the interference analysis of the two objects. I want to use the Inventor API to substract the red Interference Body of the grey object.
Thank you for your help!
Sebastian
I think you will have to derive the interfering body.ipt into the main body.ipt, relocate the origin of the body based on assembly coordinates, and then use a combine feature to subtract the body.
Thank you for your answer, @SometimesInventorMakesMeAngry!
I'll try that. I might have some problems implementing this because I'm quite new to the Inventor API.
So I might get back at you if that's okay.
