Hi all, basically what Im trying to do is to create a rectangle by using "AddAsTwoPointCenteredRectangle" command and make that rectangles center Coincident to center point of the sketch.
Here is my code
Sub Main() ' Define the inputs for the dimensions of the first rectangle Dim length1 As Double Dim width1 As Double ' Prompt the user to input the dimensions of the first rectangle length1 = CDbl(InputBox("Enter the length of the first rectangle", "Rectangle Dimensions", "10")) width1 = CDbl(InputBox("Enter the width of the first rectangle", "Rectangle Dimensions", "5")) Dim oPartCompDef As PartComponentDefinition oPartCompDef = ThisApplication.ActiveDocument.ComponentDefinition Dim oSketch As PlanarSketch oSketch = oPartCompDef.Sketches.Add(oPartCompDef.WorkPlanes.Item(3)) Dim halfLength1 As Double Dim halfWidth1 As Double halfLength1 = length1 / 2 halfWidth1 = width1 / 2 Dim oRectangleLines As Object With ThisApplication.TransientGeometry oRectangleLines = oSketch.SketchLines.AddAsTwoPointCenteredRectangle( _ .CreatePoint2d(0, 0), _ .CreatePoint2d(halfLength1, halfWidth1)) End With Dim oLine1 As SketchLine Dim oLine2 As SketchLine Dim oLine3 As SketchLine Dim oLine4 As SketchLine oLine1 = oRectangleLines(1) oLine2 = oRectangleLines(2) oLine3 = oRectangleLines(3) oLine4 = oRectangleLines(4) Dim oOriginPoint As SketchPoint oOriginPoint = oSketch.OriginPoint Dim oMidPoint As Point2d oMidPoint = oLine1.Geometry.MidPoint Dim oMidSketchPoint As SketchPoint oMidSketchPoint = oSketch.SketchPoints.Add(oMidPoint)
'This is the place where Im getting the error messages Call oSketch.GeometricConstraints.AddCoincident(oMidSketchPoint, oOriginPoint) End Sub
Im gettin this error mesage;
System.ArgumentException: Parametre hatalı. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.GeometricConstraints.AddCoincident(SketchEntity EntityOne, SketchEntity EntityTwo)
at ThisRule.Main() in rule: Rectangle, in document Core(V-01).ipt:line 47
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Can someone give me an idea ?
Solved by WCrihfield. Go to Solution.
Solved by davidt162003. Go to Solution.
I think the problem might be that the sketch origin isn't set by default. heres the code i use to do the same.
Friend Sub CoincidentCnsrt(SketchPnt1 As SketchPoint, SketchPnt2 As SketchPoint, Sketch As PlanarSketch)
Try
Sketch.GeometricConstraints.AddCoincident(SketchPnt1, SketchPnt2)
Catch ex As Exception
End Try
End Sub
Friend Sub CoincidentAtOrgin(SketchPnt As SketchPoint, Sketch As PlanarSketch, CompDef As PartComponentDefinition)
Dim OrginSkPnt = CheckOrginSkPnt(CompDef, Sketch)
CoincidentCnsrt(SketchPnt, OrginSkPnt, Sketch)
End Sub
this is just adding in the constraint and calls a sub to make sure the model origin has been projected.
Friend Function CheckOrginSkPnt(CompDef As PartComponentDefinition, Sketch As PlanarSketch) As SketchPoint
Dim OrginSkPnt As SketchPoint = Nothing
For Each pSkPnt As SketchPoint In Sketch.SketchPoints
If pSkPnt.ReferencedEntity IsNot Nothing Then
OrginSkPnt = pSkPnt
End If
Next
If OrginSkPnt Is Nothing Then
OrginSkPnt = Sketch.AddByProjectingEntity(CompDef.WorkPoints(1))
End If
Return OrginSkPnt
End Function
Just added your call the function above using the sketch object and the sketch point you want to constrain to the origin
Hi @M_F_T_. First of all, you will need to change this block of code:
End With
...to be like this:
Dim oRectangleLines As SketchEntitiesEnumerator
oRectangleLines = oSketch.SketchLines.AddAsTwoPointCenteredRectangle(oOriginPoint, _
oTG.CreatePoint2d(halfLength1, halfWidth1))
Then, you may need to either choose a different type of constraint, or different entities to constrain. You would not want to constrain the center point of the new rectangle to one of the midpoints of one of the rectangle line mid-points. That would be impossible. You may instead be able to use a horizontal or vertical type constraint between the two points, instead of a coincident one. Or use the interior constructions lines, which cross each other at the center to constrain one of their mid points to the center point, using a midpoint constraint, instead of a coincident constraint. Below is an example of your modified code that works for me.
Sub Main
Dim oPartCompDef As PartComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
Dim oOriginWP As WorkPoint = oPartCompDef.WorkPoints.Item(1)
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
oSketch.OriginPoint = oOriginWP
Dim oOriginPoint As SketchPoint = oSketch.AddByProjectingEntity(oOriginWP)
Dim oLine1 As SketchLine = oRectangleLines(1)
Dim oLine2 As SketchLine = oRectangleLines(2)
Dim oLine3 As SketchLine = oRectangleLines(3)
Dim oLine4 As SketchLine = oRectangleLines(4)
'the two construction lines crossing the center
Dim oLine5 As SketchLine = oRectangleLines(5)
Dim oLine6 As SketchLine = oRectangleLines(6)
Dim oMidPoint As Point2d = oLine5.Geometry.MidPoint
Dim oMidSketchPoint As SketchPoint = oSketch.SketchPoints.Add(oMidPoint, False)
oSketch.GeometricConstraints.AddMidpoint(oMidSketchPoint, oLine5)
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
Thank you all for your kind help. What I understand so far is that so we should project center point in either way in order to do that proccess. Am I right ?
Also another quick question is ;
Can you advise a little tip for how to do this shape in most effective way ? even though no answer, still thank you 🙂
