Dear community,
Can someone help me with turning the code below (bulk exporter for step-files) into a bulk exporter for dwg files?
Best regards,
Cor
Sub main()
Dim oSTEPTranslator As TranslatorAddIn
Dim oContext As TranslationContext
Dim oOptions As NameValueMap
Dim oDataMedium As DataMedium
Call ConfigureoSTEPTranslatorSettings(oSTEPTranslator, oContext, oOptions, oDataMedium)
Dim oFileDlg As Inventor.FileDialog = Nothing
InventorVb.Application.CreateFileDialog(oFileDlg)
'oFileDlg.Filter = "Inventor Files (*.iam)|*.iam"
oFileDlg.DialogTitle = "Delete Ilogic Rule in drawing"
oFileDlg.InitialDirectory = ThisApplication.DesignProjectManager.ActiveDesignProject.FullFileName ' ThisDoc.Path
oFileDlg.MultiSelectEnabled = True
'oFileDlg.FilterIndex = 1
oFileDlg.CancelError = True
On Error Resume Next
oFileDlg.ShowOpen()
If Err.Number <> 0 Then
MessageBox.Show("File not chosen.", "Dialog Cancellation")
ElseIf oFileDlg.FileName <> "" Then
For Each wrd In oFileDlg.FileName.Split("|") 'Words
Dim odoc As Document = ThisApplication.Documents.Open(wrd, True)
Dim oPath As String = System.IO.Path.GetDirectoryName(odoc.FullFileName)
Dim sSubject As String = odoc.PropertySets.Item(1).Item("Subject").Value
Dim sRevisionNumber As String = odoc.PropertySets.Item(1).Item("Revision Number").Value
Dim sFileNameWOExt As String = System.IO.Path.GetFileNameWithoutExtension(odoc.FullFileName)
oDataMedium.FileName = oPath & "\" & sSubject & " - " & sFileNameWOExt & "_" & sRevisionNumber & ".stp"
Call oSTEPTranslator.SaveCopyAs(odoc, oContext, oOptions, oDataMedium)
odoc.Close
Next
MessageBox.Show("STEP-Export geslaagd.")
End Sub
Sub ConfigureoSTEPTranslatorSettings(ByRef oSTEPTranslator As TranslatorAddIn, ByRef oContext As TranslationContext, ByRef oOptions As NameValueMap, ByRef oDataMedium As DataMedium)
oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
End Sub
Best regards
