I am currently developing a C# .NET 6.0 Apllication that integrates with the Inventor COM API.
Starting Inventor and connecting/interacting with the API works fine. I just don't understand to register custom functions to intercept application events. I found a lot of examples for Addins, but none that use a standalone approach.
With the code below i can connect to Inventor, but the events are not triggering. I know the code is not beautiful, it's still more a sandbox than anything else - but why are my events not firing?
_aeh is an instance of my ApplicationEventsHandler class.
Thank you so much and all the best
internal class InventorAPI
[DllImport("ole32.dll")]
static extern int CLSIDFromProgID(
[MarshalAs(UnmanagedType.LPWStr)] string lpszProgID,
out Guid pclsid
[DllImport("oleaut32.dll", PreserveSig = false)]
static extern void GetActiveObject(
ref Guid rclsid,
IntPtr pvReserved,
[MarshalAs(UnmanagedType.IUnknown)] out Object ppunk
public static object getActiveObject(string progId)
Guid clsid;
CLSIDFromProgID(progId, out clsid);
object obj;
GetActiveObject(ref clsid, IntPtr.Zero, out obj);
return obj;
public bool connect()
Boolean _started = false;
try
_invApp = (Application)getActiveObject("Inventor.Application");
Debug.WriteLine("Connected to Inventor");
Connected = true;
catch (Exception ex)
try
Type invAppType = Type.GetTypeFromProgID("Inventor.Application");
_invApp = (Application)Activator.CreateInstance(invAppType);
_invApp.Visible = true;
_started = true;
Connected = true;
catch (Exception ex2)
Debug.WriteLine(ex2.ToString());
Debug.WriteLine("Unable to get or start Inventor");
Connected = false;
if (Connected)
_invApp = _aeh.Register(_invApp);
InvApp = _invApp;
return Connected;
public class AppEventsHandler
public Inventor.Application Register(Inventor.Application _invApp)
_invApp.ApplicationEvents.OnTranslateDocument += AppEvent_OnTranslateDocument_Handler;
_invApp.ApplicationEvents.OnTerminateDocument += AppEvent_OnTerminateDocument_Handler;
_invApp.ApplicationEvents.OnSaveDocument += AppEvent_OnSaveDocument_Handler;
_invApp.ApplicationEvents.OnRestart32BitHost += AppEvent_OnRestart32BitHost_Handler;
_invApp.ApplicationEvents.OnReady += AppEvent_OnReady_Handler;
_invApp.ApplicationEvents.OnQuit += AppEvent_OnQuit_Handler;
_invApp.ApplicationEvents.OnOpenDocument += AppEvent_OnOpenDocument_Handler;
_invApp.ApplicationEvents.OnNewView += AppEvent_OnNewView_Handler;
_invApp.ApplicationEvents.OnNewEditObject += AppEvent_OnNewEditObject_Handler;
_invApp.ApplicationEvents.OnNewDocument += AppEvent_OnNewDocument_Handler;
_invApp.ApplicationEvents.OnMigrateDocument += AppEvent_OnMigrateDocument_Handler;
_invApp.ApplicationEvents.OnInitializeDocument += AppEvent_OnInitializeDocument_Handler;
_invApp.ApplicationEvents.OnDocumentChange += AppEvent_OnDocumentChange_Handler;
_invApp.ApplicationEvents.OnDisplayModeChange += AppEvent_OnDisplayModeChange_Handler;
_invApp.ApplicationEvents.OnDeactivateView += AppEvent_OnDeactivateView_Handler;
_invApp.ApplicationEvents.OnDeactivateDocument += AppEvent_OnDeactivateDocument_Handler;
_invApp.ApplicationEvents.OnCloseView += AppEvent_OnCloseView_Handler;
_invApp.ApplicationEvents.OnCloseDocument += AppEvent_OnCloseDocument_Handler;
_invApp.ApplicationEvents.OnApplicationOptionChange += AppEvent_OnApplicationOptionChange_Handler;
_invApp.ApplicationEvents.OnActiveProjectChanged += AppEvent_OnActiveProjectChanged_Handler;
_invApp.ApplicationEvents.OnActivateView += AppEvent_OnActivateView_Handler;
_invApp.ApplicationEvents.OnActivateDocument += AppEvent_OnActivateDocument_Handler;
return _invApp;
public void UnRegister(Inventor.Application _invApp)
_invApp.ApplicationEvents.OnTranslateDocument -= AppEvent_OnTranslateDocument_Handler;
_invApp.ApplicationEvents.OnTerminateDocument -= AppEvent_OnTerminateDocument_Handler;
_invApp.ApplicationEvents.OnSaveDocument -= AppEvent_OnSaveDocument_Handler;
_invApp.ApplicationEvents.OnRestart32BitHost -= AppEvent_OnRestart32BitHost_Handler;
_invApp.ApplicationEvents.OnReady -= AppEvent_OnReady_Handler;
_invApp.ApplicationEvents.OnQuit -= AppEvent_OnQuit_Handler;
_invApp.ApplicationEvents.OnOpenDocument -= AppEvent_OnOpenDocument_Handler;
_invApp.ApplicationEvents.OnNewView -= AppEvent_OnNewView_Handler;
_invApp.ApplicationEvents.OnNewEditObject -= AppEvent_OnNewEditObject_Handler;
_invApp.ApplicationEvents.OnNewDocument -= AppEvent_OnNewDocument_Handler;
_invApp.ApplicationEvents.OnMigrateDocument -= AppEvent_OnMigrateDocument_Handler;
_invApp.ApplicationEvents.OnInitializeDocument -= AppEvent_OnInitializeDocument_Handler;
_invApp.ApplicationEvents.OnDocumentChange -= AppEvent_OnDocumentChange_Handler;
_invApp.ApplicationEvents.OnDisplayModeChange -= AppEvent_OnDisplayModeChange_Handler;
_invApp.ApplicationEvents.OnDeactivateView -= AppEvent_OnDeactivateView_Handler;
_invApp.ApplicationEvents.OnDeactivateDocument -= AppEvent_OnDeactivateDocument_Handler;
_invApp.ApplicationEvents.OnCloseView -= AppEvent_OnCloseView_Handler;
_invApp.ApplicationEvents.OnCloseDocument -= AppEvent_OnCloseDocument_Handler;
_invApp.ApplicationEvents.OnApplicationOptionChange -= AppEvent_OnApplicationOptionChange_Handler;
_invApp.ApplicationEvents.OnActiveProjectChanged -= AppEvent_OnActiveProjectChanged_Handler;
_invApp.ApplicationEvents.OnActivateView -= AppEvent_OnActivateView_Handler;
_invApp.ApplicationEvents.OnActivateDocument -= AppEvent_OnActivateDocument_Handler;
public void AppEvent_OnActivateDocument_Handler(_Document DocumentObject, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnActivateDocument");
HandlingCode = HandlingCodeEnum.kEventHandled;
public void AppEvent_OnActivateView_Handler(Inventor.View ViewObject, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnActivateView");
public void AppEvent_OnActiveProjectChanged_Handler(DesignProject ProjectObject, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnActiveProjectChanged");
public void AppEvent_OnApplicationOptionChange_Handler(EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnApplicationOptionChange");
public void AppEvent_OnCloseDocument_Handler(_Document DocumentObject, string FullDocumentName, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnCloseDocument");
public void AppEvent_OnCloseView_Handler(Inventor.View ViewObject, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnCloseView");
public void AppEvent_OnDeactivateDocument_Handler(_Document DocumentObject, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnDeactivateDocument");
public void AppEvent_OnDeactivateView_Handler(Inventor.View ViewObject, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnDeactivateView");
public void AppEvent_OnDisplayModeChange_Handler(Inventor.View ViewObject, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnDisplayModeChange");
public void AppEvent_OnDocumentChange_Handler(_Document DocumentObject, EventTimingEnum BeforeOrAfter, CommandTypesEnum ReasonsForChange, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnDocumentChange");
public void AppEvent_OnInitializeDocument_Handler(_Document DocumentObject, string FullDocumentName, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnInitializeDocument");
public void AppEvent_OnMigrateDocument_Handler(_Document DocumentObject, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnMigrateDocument");
public void AppEvent_OnNewDocument_Handler(_Document DocumentObject, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnNewDocument");
public void AppEvent_OnNewEditObject_Handler(object EditObject, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnNewEditObject");
public void AppEvent_OnNewView_Handler(Inventor.View ViewObject, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnNewView");
public void AppEvent_OnOpenDocument_Handler(_Document DocumentObject, string FullDocumentName, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnOpenDocument");
public void AppEvent_OnQuit_Handler(EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnQuit");
public void AppEvent_OnReady_Handler(EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnReady");
public void AppEvent_OnRestart32BitHost_Handler(EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnRestart32BitHost");
public void AppEvent_OnSaveDocument_Handler(_Document DocumentObject, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnSaveDocument");
public void AppEvent_OnTerminateDocument_Handler(_Document DocumentObject, string FullDocumentName, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnTerminateDocument");
public void AppEvent_OnTranslateDocument_Handler(bool TranslatingIn, _Document DocumentObject, string FullFileName, EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
Debug.WriteLine("OnTranslateDocument");
Solved by Dev_rim. Go to Solution.
Hi there,
To trigger an event, you don't need to return application object again and again.
Lets try this code, you also should use (new) statement.
private Inventor.Application m_inventorApplication;
private Inventor.ApplicationEvents m_appEvents;
public void Main()
// You should fill application and Application events object here. Its important, you have to Delcare them above the function but inside of the class.
m_inventorApplication = application;
m_appEvents = m_inventorApplication.ApplicationEvents;
// Then if you need you can activate(start or trigger) the event.
Activate();
public void Activate()
//Its important, You need to fill them with "new" and then Sink_Handler and the name of the function.
m_appEvents.OnActivateDocument += new ApplicationEventsSink_OnActivateDocumentEventHandler (ApplicationEvents_OnActivateDocument);
public void Deactivate()
m_appEvents.OnActivateDocument -= new ApplicationEventsSink_OnActivateDocumentEventHandler(ApplicationEvents_OnActivateDocument);
private void ApplicationEvents_OnActivateDocument(_Document DocumentObject,EventTimingEnum BeforeOrAfter, NameValueMap Context, out HandlingCodeEnum HandlingCode)
//Here is inside of the event. If you want to reach more info, i will share an article below this code peace.
HandlingCode = Inventor.HandlingCodeEnum.kEventNotHandled;
if (BeforeOrAfter !=Inventor.EventTimingEnum.kAfter)
return;
HandlingCode = Inventor.HandlingCodeEnum.kEventHandled;
Console.WriteLine("OnActivateDocument");
Also, maybe you want to see this article:
https://modthemachine.typepad.com/my_weblog/2013/07/inventor-events-using-net-3-examples.html
Regards
Devrim
Thank you so much! I have integrated your recommendations and went with your code example and it works!
Awesome, thank you so much!!!
