Hey guys,
Can you help me creating a rule that will sort every sheet in an .idw with the same order that is in the assembly.
I already have a rule to write the part number of the part/assy as the sheet name and another to sort sheets by name. The problem (one of them) is when the assy name is alphabetically greater than the parts inside of it. This way, assy's sheet appears after its parts sheets and them I have to re sort them manually.
I have a multi sheet drawing that contains every part in an assembly, having that assembly and drawing (.idw) the same name. The objective is to get the order of every file (.ipt and .iam) contained in the main assembly and, for the same part number in the .idw, sort it likewise.
There's the possibility that the same part is used in different assemblies, so the respective drawing only appears the first time. I placed some prints of the assembly browser and the idw browser sorted by sheet name and sorted like the objective of this rule.
Hope you can help me. It will save me a lot of time for the pdf to be in the correct paging order.
RB
Can you attach the code your using and your attemp so far at automating this?
One method to do this would be to loop through occurrences check document type check if it is an assembly then check sub occurrences.
You could try something like this:
Sub Main()
Dim doc As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = doc.ActiveSheet
Dim view As DrawingView = sheet.DrawingViews.Item(1)
Dim refDoc As AssemblyDocument = view.ReferencedDocumentDescriptor.ReferencedDocument
Dim names As New List(Of String)
Dim browser As BrowserPane = refDoc.BrowserPanes.Item("Model")
Dim node As BrowserNode = browser.TopNode
names.Add(GetNodeName(node))
RetriefNames(node, names)
Dim sheets As New Dictionary(Of String, BrowserNode)
Dim drawingBrowser As BrowserPane = doc.BrowserPanes.Item("Model")
For Each node1 As BrowserNode In drawingBrowser.TopNode.BrowserNodes
sheets.Add(GetNodeName(node1), node1)
Next
Dim previousNode = drawingBrowser.TopNode.BrowserNodes.Item(1)
For Each name As String In names
Dim foundSheets = sheets.Where(Function(s) s.Key.StartsWith(name))
If (foundSheets.Any()) Then
Dim foundSheetNode = foundSheets.First().Value
drawingBrowser.Reorder(previousNode, False, foundSheetNode)
previousNode = foundSheetNode
End If
Next
End Sub
Public Sub RetriefNames(mainNode As BrowserNode, names As List(Of String))
For Each node As BrowserNode In mainNode.BrowserNodes
Try
' this if statement can be slow on large assemblies.
' but will also check patterens.
If (Not TypeOf node.NativeObject Is ComponentOccurrence And
Not TypeOf node.NativeObject Is CircularOccurrencePattern And
Not TypeOf node.NativeObject Is RectangularOccurrencePattern And
Not TypeOf node.NativeObject is OccurrencePatternElement) Then Continue For
' this is faster ;-)
' If (Not TypeOf node.NativeObject Is ComponentOccurrence) Then Continue For
Catch ex As Exception
End Try
Next
End Sub
Public Function GetNodeName(node As BrowserNode)
Dim nameParts = node.BrowserNodeDefinition.Label.Split(":")
Return nameParts(0)
End Function
Jelte de Jong
Blog: hjalte.nl - github.com
Hi @JelteDeJong ,
Thanks for your help. That's exactly what I was looking for.
I just had to make one little adjustment (line 56), cause it failled when I have more than one instance of a part inside the assembly.
Made another change to force the drawing, with the same name as the idw, to become at the top of the sheetlist but that's a personal fining.
Here's the final code:
Sub Main()
If ThisDoc.PathAndFileName = "" Then
MessageBox.Show("Save file before running this macro!", "Warning")
Exit Sub
End If
Dim index As Integer=0
For Each oSheet As Sheet In doc.Sheets
index = index + 1
If ThisDoc.FileName = Left(oSheet.Name, InStrRev(oSheet.Name, "_") -1) Then Exit For
Next
Dim sheet As Sheet = doc.Sheets(index)
Next
End If
Next
End Sub
Try
Not TypeOf node.NativeObject Is OccurrencePatternElement) Then Continue For
If Not names.Contains(GetNodeName(node)) Then
End If
End Try
Next
End Sub
Return nameParts(0)
End Function
