'hier shows only occurence name. I need part name. Pls help me some one. Thanks
Sub Main()
If ThisApplication.ActiveDocumentType = kAssemblyDocumentObject Then
CreatePartNumberAnnotation()
'MessageBox.Show("ich bin Assembly", "ich muss assembly sein")
Else
MessageBox.Show("Sorry ich bin kein ssembly", "Ich muss assembly sein")
End Sub
Sub CreatePartNumberAnnotation()
Dim Doc As Document = ThisApplication.ActiveDocument
Dim oDef As AssemblyComponentDefinition = Doc.ComponentDefinition
Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
Dim dViewRepMgr As RepresentationsManager = oDef.RepresentationsManager
Dim dWeldView As DesignViewRepresentations = dViewRepMgr.DesignViewRepresentations
Dim oEdge As Edge = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "Select an Edge to attach leader")
Dim o As ComponentOccurrence = oEdge.ContainingOccurrence
Dim oAnnoPlaneDef As AnnotationPlaneDefinition = oDef.ModelAnnotations.CreateAnnotationPlaneDefinitionUsingPlane(oEdge.Geometry)
Dim oLeaderPoints As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
'finding Midpoint of an Edge
Dim startPoint As Point = oEdge.StartVertex.Point
Dim endPoint As Point = oEdge.StopVertex.Point
Dim midPointX As Double = (startPoint.X + endPoint.X) / 2
Dim midPointY As Double = (startPoint.Y + endPoint.Y) / 2
Dim midPointZ As Double = (startPoint.Z + endPoint.Z) / 2
'midmoint found
'accesing components name if it is a occurance
' i have problem in this part of code. help pls .
Dim sel_set As SelectSet
sel_set = ThisDoc.Document.SelectSet
If sel_set.Count = 1 Then
If TypeOf sel_set.Item(1) Is ComponentOccurrence Then
Doc = sel_set.Item(1).definition.document
Else
MessageBox.Show("part or assembly must be selected", "Title")
Else
MessageBox.Show("Only one component can be selected", "Title")
Exit Sub
'name acessed
Call oLeaderPoints.Add(oTG.CreatePoint(midPointX,midPointY,midPointZ))
Dim oLeaderIntent As GeometryIntent = oDef.CreateGeometryIntent(oEdge)
Call oLeaderPoints.Add(oLeaderIntent)
Dim oLeaderDef As ModelLeaderNoteDefinition= oDef.ModelAnnotations.ModelLeaderNotes.CreateDefinition(oLeaderPoints, Doc.DisplayName, oAnnoPlaneDef) 'and here show else part.
Dim oLeader As ModelLeaderNote = oDef.ModelAnnotations.ModelLeaderNotes.Add(oLeaderDef)
End Sub
