Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Shortcut key for component visibility
3 REPLIES 3
DRoam
2341 Views, 3 Replies
I'd like to set up a keyboard shortcut so that when I press the 'V' key, inventor toggles the visibility of the selected part or assembly. However, "Visibility" seems to be about the only command that doesn't exist in the list of keyboard shortcuts*. I found this post in which someone says it's not possible, but might be using VBA. I've done some iLogic but know nothing about Inventor's inner-working VBA. I'm wondering if there's some workaround, VBA or otherwise, that'll allow me to toggle visibility using the 'V' key. Any suggestions would be appreciated. Thanks!
*actually it does but it says it's only available for use in Inventor Studio. Go figure.
Using: Autodesk Inventor 2013 Product Design Suite
3 REPLIES 3
adam.nagy
in reply to: DRoam
You could create a VBA command like this:
Sub ToggleVisibility()
    Dim ss As SelectSet
    Set ss = ThisApplication.ActiveDocument.SelectSet
    Dim obj As Object
    For Each obj In ss
        If TypeOf obj Is ComponentOccurrence Then
            Dim occ As ComponentOccurrence
            Set occ = obj
            occ.Visible = Not occ.Visible
    Next
End Sub
And then assign the V key to it in the "Customize" dialog (right-click anywhere on the Ribbon and select "Customize User Commands")
As you can see in my case there are two commands already using that shortcut, so when I press 'V', I will have to select which command should run:
I hope this helps.
Cheers,
Adam Nagy
Autodesk Platform Services
DRoam
in reply to: adam.nagy
That works perfectly, thanks so much!
dusan.naus.trz
in reply to: DRoam
this is super, I also thanks so much adam.nagy. I work in version 2014, and I think that is not even in version 2016.
