SheetMetal in assembly API VB.NET
2 REPLIES 2
florian_wenzel
273 Views, 2 Replies
florian_wenzel
Inventor 2022
API. VB.NET Visual Studio
I try to Change SubType of a Part (From Part to  SheetMetal) in Assembly Enviroment.
My Goal i to Create a CounterFlange
The Problem is to change the SubType Docuemnt.
I Think, the Problem is, that iam i SubAssembly, ActiveDocument is Probably the Main Assembly.
How i can make the PartDocuemnt Active in Assembly?
Is this the Problem ?
This is My Code:
        Dim oArc As SketchArc
        oArc = oSketchPart_A.SketchArcs.AddByCenterStartEndPoint(oPointCenterArc, oSketchLine_06.EndSketchPoint, oSketchLine_07.EndSketchPoint)
        Dim oPathline As Path = oPart_A_Def.Features.CreatePath(oArc)
        oOccAssembly_Middle.Edit()
        'oOccPartA.Edit()
        Dim oRefComponents As ReferenceComponents = oPart_A_Def.ReferenceComponents
        g_inventorApplication.ActiveDocument.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
        oPartA.Update()
        Dim oSheetCompDef As SheetMetalComponentDefinition = oPartA.ComponentDefinition
        Dim oSheetMetallFeatures As SheetMetalFeatures = oSheetCompDef.Features
        Dim oStyle As SheetMetalStyle
        oStyle = oSheetCompDef.SheetMetalStyles.Item(1)
        oStyle.Thickness = "2"
        oStyle.BendRadius = "Stärke"
        oStyle.BendReliefDepth = "Stärke * 0.5"
        oStyle.BendReliefShape = BendReliefShapeEnum.kRoundBendReliefShape
        oStyle.BendReliefWidth = "Stärke"
        oStyle.BendTransition = BendTransitionEnum.kArcBendTransition
        oStyle.BendTransitionArcRadius = "Stärke * 2.0"
        oStyle.CornerReliefShape = CornerReliefShapeEnum.kRoundCornerReliefShape
        oStyle.CornerReliefSize = "Stärke * 4.0"
        oStyle.MinimumRemnant = "Stärke * 2.0"
        oPartA.Update()
        Dim oContourFlanges As ContourFlangeFeatures = oSheetCompDef.Features.ContourFlangeFeatures
        Dim oContourFlangeDef As ContourFlangeDefinition
        oContourFlangeDef = oContourFlanges.CreateContourFlangeDefinition(oPathline)
        Call oContourFlangeDef.SetDistanceExtent(13, PartFeatureExtentDirectionEnum.kPositiveExtentDirection)
        Dim oContourFlange As ContourFlangeFeature = oContourFlanges.Add(oContourFlangeDef)
I got Error:
Wrong Parameter
Inventor 2022
This is My Code:
        'oOccPartA.Edit()
        oPartA.Update()
        oPartA.Update()
I got Error:
Wrong Parameter
2 REPLIES 2
JelteDeJong
This is how you can change a part of an assembly.
Dim doc As AssemblyDocument = ThisDoc.Document
' Get the part occurrence object
Dim oOccPartA = doc.ComponentDefinition.Occurrences.
    Cast(Of ComponentOccurrence).
    Where(Function(o) o._DisplayName = "PartA").
    FirstOrDefault()
' Get the document that is refrenced by the occurrence
Dim partDoc As PartDocument = oOccPartA.ReferencedDocumentDescriptor.ReferencedDocument
' Change the sub type
partDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
Jelte de Jong
Blog: hjalte.nl - github.com
    FirstOrDefault()
Jelte de Jong
florian_wenzel
Hi @JelteDeJong ,
Thanks for Help
Thanks for Solution.
oPartA.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
Hi @JelteDeJong ,
Thanks for Help
