Sheet size not displaying
I am new to Inventor however used many packages before but this one baffles me therefore hoping someone may be able to assist. I'm hoping to display a drawing sheet size in my title block of which all sizes seem to show except for one which is a B1 size. I suspect it may be due to adding the B1 which does't seem to be available as a default therefore having created this myself. The sheet format seems to adjust working as expected using my border SHL_01 and both Title Blocks SHL_01 and SHL-RE-01 except for the size which displays as "Custom Size (mm)". How top I get this to display B1 not "Custom Size (mm)"?
I have attached some screen captures which indicate my project, confirms my sheet text parameter and sheet editor setting. Thanks in advance
It appears this may not be possible as I found the following https://www.cadtutor.net/forum/topic/4720-sheet-sizes-in-idw-template/
I hope Autodesk have looked into this as this was posted in 2010
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Unfortunately, Inventor does not support to add sheet size. Please log this wish list at idea station using below link.
https://forums.autodesk.com/t5/inventor-ideas/idb-p/v1232
Otherwise, you may have to use prompt entry. For more details on prompt entry, go through the below blog link.
https://adndevblog.typepad.com/manufacturing/2016/03/prompted-entry-prompted-texts-promptstrings.html
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
