Could someone Please š modify the code below to use a custom i-property <MARK> in place of the ("Part Number")
and remove the ("Description")
thanks in advance.
Sub Main
If TypeOf ThisDoc.Document Is DrawingDocument Then
Dim dwgDoc As DrawingDocument = ThisDoc.Document
For Each dwgSheet As Sheet In dwgDoc.Sheets
If dwgSheet.DrawingViews.Count > 0 Then
modelFile = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.FullDocumentName
modelDoc = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.ReferencedDocument
prtNumber = modelDoc.PropertySets("Design Tracking Properties").Item("Part Number").Value & " - " & _
modelDoc.PropertySets("Design Tracking Properties").Item("Description").Value
If Not String.IsNullOrEmpty(prtNumber) Then
dwgSheet.Name = prtNumber
End If
End If
Next
End If
End Sub
Solved by JhoelForshav. Go to Solution.
Here is a list of all properties and a few samples.
https://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
Assuming MARK is coming from the model you can do this.
Create a new variable called Mark then change the property set name to āInventor User Defined Propertiesā then change the property your targeting and your done.
Mark = modelDoc.PropertySets("Inventor User Defined Properties").Item("MARK").Value
Delete prtNumber and itās associate lines and insert the above piece of code and then change Mark wherever prtNumber appears.
Alen,
Thank you for your reply, I zero experience with i-logic could you possibly edit the code or high light the text that needs to be removed and where i need to insert the text you suggested.
I would appreciate any help you have to offer.
thanks, Ed
Try this @estewart3E8B6
Sub Main If TypeOf ThisDoc.Document Is DrawingDocument Then Dim dwgDoc As DrawingDocument = ThisDoc.Document For Each dwgSheet As Sheet In dwgDoc.Sheets If dwgSheet.DrawingViews.Count > 0 Then modelFile = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.FullDocumentName modelDoc = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.ReferencedDocument mark = modelDoc.PropertySets("Inventor User Defined Properties").Item("MARK").Value If Not String.IsNullOrEmpty(mark) Then dwgSheet.Name = mark End If End If Next End If End Sub
Jhoel Forshav
Download my free Inventor Addin - Hole Projector
LinkedIn | Ideas | Contributions | Blog posts | Website
Thank You for your reply. I received the following,
Error in rule: SHEET RENAME 2, in document: KING POST ARRANGEMENT.idw
Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
at Microsoft.VisualBasic.CompilerServices.LateBinding.LateGet(Object o, Type objType, String name, Object[] args, String[] paramnames, Boolean[] CopyBack)
at Microsoft.VisualBasic.CompilerServices.NewLateBinding.LateGet(Object Instance, Type Type, String MemberName, Object[] Arguments, String[] ArgumentNames, Type[] TypeArguments, Boolean[] CopyBack)
at ThisRule.Main()
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
You didn't attach all the necessary files. Theres a derived part and some image for the drawing that these files reference as well. I did manage to open the drawing and part by skipping these references though, and it works fine for me...
Jhoel Forshav
However, that error message would show if the custom property "MARK" doesn't exist in the model document. Try this code instead that gives you a warning if the property doesn't exist š
Sub Main If TypeOf ThisDoc.Document Is DrawingDocument Then Dim dwgDoc As DrawingDocument = ThisDoc.Document For Each dwgSheet As Sheet In dwgDoc.Sheets If dwgSheet.DrawingViews.Count > 0 Then modelDoc = dwgSheet.DrawingViews(1).ReferencedDocumentDescriptor.ReferencedDocument Try mark = modelDoc.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}").Item("MARK").Value Catch MsgBox("The custom property ""MARK"" doesn't exist in the part " & modelDoc.FullFileName) End Try If Not String.IsNullOrEmpty(mark) Then dwgSheet.Name = mark End If End If Next End If End Sub
Jhoel Forshav
Thanks again, did you run the SHEET RENAME 2 Rule, or the SHEET RENAME which uses the "Part Number" Not <Mark>.
Could you please attach the files that work for you.
Ed
